r3c FOG LIGHT SPECS - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-02-2009, 04:16 PM   #1 (permalink)
jsy
Newbie
Talking r3c FOG LIGHT SPECS
Years ago I was the sales manager in Newnan GA for a Triumph dealership. Won't go into details but the company no longer exists. We had an RIII go down and I was given the R3C (A9738110) fog lamps which i had mounted to my Yamaha Roadstar. Did a half assed job and tried to tie them directly into the head lamp - had them mounted on the forks and they looked/worked well. I want to put them back on, but this time I would like to go ahead and get a correct wiring harness/switch which I figured I would run straight off of the battery.
Question is if I'm running both lights into one line what gauge (wiring) harness should i get and what would be the correct in line fuse amperage?
Appreciating the input in advance, and quite honestly if my bike wasn't already paid off, I would jump on a Triumph in a heartbeat. I had the pleasure of Demo and RAT rides and man those were the day's!! Sprints, Triples, Tigers RIII's, Bonnies and Daytona's - WOOHOO!
jsy is offline   Reply With Quote
Old 11-03-2009, 02:00 PM   #2 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
It depends on what current the lights draw, but I have both Speed Four headlights soldered into one 14 gauge wire with no overload issues. A 15 amp inline fuse should suffice. Make sure that whatever toggle switch you use is a high quality all-weather one (probably a marine application), as the cheap ones won't hold up to the elements.
"My life stood-a Loaded Gun- / In Corners-till a Day / The Owner passed-identified- / And carried Me away- /. . .Though I than He-may longer live / He longer must-than I- / For I have but the power to kill, / Without-the power to die-" E.Dickinson
BombFactory is offline   Reply With Quote
Integrated Tail light, brake light and turn signals?? stinger Sprint Forum 15 04-03-2007 10:21 PM
handlebar specs for 03 S3???? nakedlover Speed Triple Forum 6 02-27-2007 05:18 PM
Oil specs please Ruxton Twins Technical Talk 5 12-11-2006 12:49 AM
Intermittent Fault - Engine warning light & Fuel light Tassie_Tiger Tiger Chat 4 06-13-2006 09:58 AM
Light specs and wiring info LiveTheDream Speed Triple Forum 1 06-22-2004 07:39 AM
