Hi,
I think you will find they are fitted as part of the original OEM brakeline for the bike. If you still have the original lines, then you can slit them off, and transfer them.
You may be able to get hold of a couple from one of the companies that make up brakelines, as I did. Again you will have to slit them, and then put some silicon on to help seal/hold them once fitted.
If we ever replace them again, we now know to specify them in the construction of the new brakeline. (Shouldn't be that way, but it appears to be so).
Geoff
