t140v 724cc valve gaping specs - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 10-21-2009, 05:48 AM   #1 (permalink)
any insight is great. i have lots of backfiring at the adjustment i made to the 748cc specs
1973 724 is offline   Reply With Quote
Old 10-22-2009, 04:30 PM   #2 (permalink)
Hi Mate, can you be a bit more specific with what the symptons are & what you have done/adjusted?
Paul.
hayabusaman0 is offline   Reply With Quote
Old 10-23-2009, 05:54 PM   #3 (permalink)
Paul.
electeonic ignition, mikuni 32mm carbs, new fuel taps, oil change *(the oil sludge was so thick it would stand up on my finger. i've only had it 3 months. thats what i've done so far it has sat for years... oh and it has good compression
Old 10-23-2009, 08:26 PM   #4 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
I haven't worked on your model, but from what I know the 750 is a bored out 724. I wouldn't think there would be a change in valve clearance adjustment, although a manual or knowledgeable member can answer that for sure.
Regardless, a difference in .010" or so in adjustment shouldn't produce backfiring if the engine hasn't been run that way for long. What exactly did you set the valve clearance to, how did you do so, and did you do anything to the camshaft or ignition timing?
The Resurrection: ’02 CE Speedtona w/GSXR Forks
The Reviving: Speed-TT Project
"When I reflect upon the number of disagreeable people who I know have gone to a better world, I am moved to lead a different life." - Pudd'nhead Wilson
BombFactory is offline   Reply With Quote
Valve Timing Marks T140V thirdbike Classic, Vintage & Veteran 7 05-09-2009 10:20 AM
Valve clearance specs? boredinocala Sprint Forum 5 07-27-2006 06:28 PM
Torque Specs for the Clutch cover of T140V JDx613 Twins Talk 1 10-13-2005 09:00 PM
02 ST VALVE SPECS NEEDED Sprint Forum 8 10-15-2004 01:00 AM
