DIY suspension alignments tools - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGearHonda Powersports
Old 09-30-2009, 11:08 PM   #1 (permalink)
Favourite Bike: Daytona 600
Motorcycle suspension alignment using strings, trammell bars and laser beam.
youtube.com/watch?v=HcQW_u2AZM8
dealsgapdragon is offline   Reply With Quote
Old 10-04-2009, 04:25 PM   #2 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
I don't think many of these tools shown in the video are accurate methods of measuring chassis/wheel alignment.
The plumb-bob methods proves nothing regarding wheel alignment, as it is totally dependent on the subframe alignment--whether or not the wheel is plumb. There is factory slop in the subframe mounting holes, and a 1/32" discrepancy between the right and left sides at the mounting holes will come out much larger at the back of the tail fairing where the plumb-bob is attached.
The trammel bar method is a good one, but not when using what appears to be pieces of screen door aluminum; these are probably the least likely pieces of metal to be straight. Using 1" x 2" rectangular tubing or, even better, proper straight edge steel or quality 8' levels would be much more accurate.
The string method is a good one, and it shows in the video that there is a 17/32" right offset (with a 1/32 discrepancy on the left side of the front wheel which could always be a wave in the wheel's lip). However, the plywood methods look unreliable at best. For instance, there is an almost perfect 17/32" offset to the right according to the string line method; however, when the piece of plywood is held up against the right side of the front tire and a laser beam is shot from the rear, the laser beam is one-hash mark to the right of the third parallel line on the plywood towards the back of the bike (I don't know if these are 1/8" or 1/4" hashes), but then the laser beam intersects the third parallel line towards the front. This cannot mathematically happen if there is an even 17/32" right offset, which proves that their is either fault in the method of measuring or in the measuring tools.
Alignment measurements are about consistency and require proper, straight tools. I don't see very consistent measurements between the different methods shown in the video--nor is there apparent control in the points of measurement--so I'm not sure why these should be regarded as accurate tools that others can use to measure their alignment when they cannot properly measure the alignment in the video.
"My life stood-a Loaded Gun- / In Corners-till a Day / The Owner passed-identified- / And carried Me away- /. . .Though I than He-may longer live / He longer must-than I- / For I have but the power to kill, / Without-the power to die-" E.Dickinson
BombFactory is online now   Reply With Quote
Tell me about your tools. (not like that!) dryheat Twins Technical Talk 6 04-16-2008 12:33 PM
Got some new tools 10860 Twins Talk 18 09-10-2007 12:00 PM
Tools for Suspension Adjustment? DJRenton Sprint Forum 8 07-25-2007 02:42 PM
Tools mglemans86 Biker Hang-Out 11 01-18-2007 04:06 AM
Tools for the job nav18tor T3 Sport / Touring Forum 9 06-29-2006 06:02 PM
