Daytona 675 temp failure - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 09-26-2009, 01:12 PM   #1 (permalink)
Newbie
Hi all
Hope you can help a dane here.
After 2 hours of ride yesterday and unfortunately 30 minutes of queue at the highway, which caused the fan to cool the engine, the temperature suddenly fell down to just one 'mark' at the display. Today there was no temperature shown at all in the display??
What has gone wrong? Some electrical issue or mecanical? Is it a known problem for some of the more experienced?
I will of course visit the local triumphdealer as soon as possible, but just want to know if I can take the bike the same way back tomorrow without overheating or damaging the bike?
Hope some of you know more ..?
Kondi is offline   Reply With Quote
Old 09-26-2009, 03:01 PM   #2 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
Kondi, Ensure that the system has coolant (engine cold), check the fuses and ride home when there is the least chance of a traffic tie up. Other alternative is to tow it back as there is a possibility that the fan won't run when needed if the temperature sensor isn't working.
Good luck,
Brad
Old 09-26-2009, 03:55 PM   #3 (permalink)
Newbie
Thanks Brad
I'll check the fuses - thought of that aswell tonight. Otherwise I'll cross my fingers and drive all the way home tomorrow without any heating problems.
Lovely bike anyways!
Old 09-28-2009, 05:19 AM   #4 (permalink)
Newbie
Ok, just to let you know, the bike went all back to normal yesterday when I went back home on the highway. Ended up in the queue again, and no doubt the engine got hotter. But suddenly the temp bars on the display raised from 1 to 5 again. The fan started and I could continue on a "normal" bike the last 150 km.
Let's hope it was just an overheating confusion ...
ppffeww.
Old 09-28-2009, 09:49 AM   #5 (permalink)
bradtx's Avatar
Kondi, Nice to read that. You might want to check the coolant temperature sensor operation should the trouble arise again. A better step may be to replace it ... alot cheaper than if the engine overheats for lack of the fan running.
Brad
Old 09-28-2009, 05:36 PM   #6 (permalink)
Immoderate Moderator
Favourite Bike: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: Dead '96 Trident in NYC
Brad, are you sure the coolant temp sensor is part of the fan circuit? I don't know the 675s at all, but on the old 885s the coolant temp sensor is connected to the coolant temp gauge and the thermostat is what controls the fan. On those motors, you could replace the coolant temp sensor with a bolt and it wouldn't affect the fan's operation. Which is good, because they failed pretty often.
Cheers,
-Kit
KitNYC is online now   Reply With Quote
Old 09-29-2009, 01:25 AM   #7 (permalink)
bradtx's Avatar
Kit, I don't know anything about the D675. Some FI ECUs use the temp sensor input to run the temp gauge and a radiator fan. The D955 seems to.
When Kondi has the dealer check out the problem it hopefully won't test okay.
Brad
Old 09-29-2009, 02:33 AM   #8 (permalink)
KitNYC's Avatar
Anybody know for sure? How about for Gen 2 955s? I can see from the diagram that my Sprint's temp sensor feeds into the ECU, so I'm tempted to assume it controls the fan, but I made the same assumption about the 885 and I was wrong there...
Cheers,
-Kit
Serious suspension failure kenoath Sprint Forum 40 05-19-2009 08:22 AM
Daytona temp gauge Ozbernie T3 Sport / Touring Forum 5 01-14-2008 06:06 PM
High Temp. Solution is a Failure. fivehundo Daytona Deliberations 0 09-04-2006 01:46 AM
Daytona 600 running temp/oil level question gladgd Triumph SuperSports 9 05-05-2005 03:30 PM
light failure Speed Triple Forum 1 12-13-2004 12:46 PM
