Long story short, I recently had my dealership correct a pinched/shorted wire with my Triumph heated grips...
http://www.triumphrat.net/sprint-for...ttle-side.html
Kudos and all to my service manager for hooking me up, however, now I have this strange problem...my grips wont shut off. Despite the switch position, they heat up. Not going to be a problem in 4 or 5 months, but my afternoon commute is going to be a bit troublesome in the meantime.
I plan on asking, but I don't think my dealer touched the switch; the issue was at the Throttle connection. And even if he did, I'm not sure what he could have done.
I'm guessing a voltmeter on the switch contacts might be a good place to start (and I have to replace a dead bulb on that side), but any other suggestions for troubleshooting? Is there some sort of electrical situation that might explain this behavior?
I Googled a bit, but as you can probably tell, I'm a bit electrically challenged and am not sure what I'm looking for.
Thanks in advance.
