Triumph Bonneville Only Running on 1 Cylinder
Hi All
I have a 2001 Truimph Bonneville. It started cutting out when the tank was low on fuel. Reserve made no difference. Filled up with fuel and all was okay until low again.
Drained and cleaned tank, line, drained and cleaned the carbs (without stripping them). Replaced all parts, still no difference.
Bike would run for 20km then fire only on one cylinder and then die. Wait 5 minutes, start again and then run for 2km, drop to one cylinder and then die again.
In the wintertime, when the temps are 20C, it ran better. Now in the summertime, 32C+, its very much worse.
Cleaned all electrical connections. Replaced spark plugs, HT leads, HT coil, pickup coil. Now it will run with the choke out but cuts out when the choke is closed.
Now stuck for what to try next. Help greatly appreciated.
One frustated, house bound biker.
