Something draining the battery - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 09-06-2009, 12:13 AM   #1 (permalink)
Favourite Bike: 73' T140RV
Pipes73's Avatar
Other Motorcycle: 05' Thruxton
Extra Motorcycle: 06' T100
Question Something draining the battery
I finally got my T140RV's gear box & shifter lever back together. I rode it to work last Monday and everything was good. It started up on the first kick & rode perfectly. At quitting time it kicked over on the 2nd kick; not bad I thought to myself. But on the route home I had to stop for some construction about 2 blocks from the office & the motor died. I pushed it over to the side of the road & it wouldn't start. I looked at the headlamp & it was very very dim. Thankfully my family was home to rescue me. Anyways to get to the point something is draining my battery. How do I figure out what the culprit is? Is there an easy test for this sort of thing?
Pipes73 is offline   Reply With Quote
Old 09-06-2009, 12:21 AM   #2 (permalink)
Administrator
Favourite Bike: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
First thing to check is if the charging system is in fact charging.
What will drain the battery with the bike running is the ignition and lights etc, if the charging system is not doing its job.
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is offline   Reply With Quote
Old 09-06-2009, 12:56 PM   #3 (permalink)
Pipes73's Avatar
Is there a method to do this? Or is it just a matter of getting out the volt meter & checking the lights, ignition, etc with the bike not running & see if any of them are drawing power.
Old 09-08-2009, 01:09 AM   #4 (permalink)
Favourite Bike: '98 Thunderbird Sport
denny's Avatar
Other Motorcycle: '06 Husqvarna TE 610
Extra Motorcycle: '95 TBird - Project
Check the voltage at the battery.
Running and not running.
For current bikes
Running should be about 14 - 14.5 volts - at 3000 RPM
Not running should be a little above 12 volts.
That's with a really good strong battery.
Cheers,Denny
denny is offline   Reply With Quote
Old 09-08-2009, 08:25 PM   #5 (permalink)
Pipes73's Avatar
I don't know anything about electrical systems. And looking at the wiring diagram in the shop manual doesn't clear it up for me either so any insight will will be appreciated. I charged the battery up to 12 volts & used the meter to try & figure out what the drain is. I left the motor off when I did the testing. Is the ignition suppose to have power running through it even when the switch is in the off position? I know Wombat said the ignition could be the problem but is this what he was talking about?
battery draining hodgy T3 Sport / Touring Forum 4 07-19-2008 01:31 PM
Coolant Draining 07speedtriple Speed Triple Forum 4 05-13-2008 01:32 AM
Draining the motor oil gregp Hinckley Classic Triples 4 02-19-2008 01:28 AM
Draining The Tank Bonnebret Twins Technical Talk 6 09-11-2007 12:59 PM
Draining battery continues.. whodkne Speed Triple Forum 7 05-07-2007 12:33 PM
