after market air filters - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-05-2009, 11:56 PM   #1 (permalink)
Newbie
Favourite Bike: 79 t140e black
I am installing wire screen cone after market filters on my bonneville and was wonder if I need to cote the screen with oil and could I use motor oil or transmission fluid or use nothing?
triumpht140 is offline   Reply With Quote
Old 09-06-2009, 03:18 AM   #2 (permalink)
Immoderate Moderator
Favourite Bike: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: Dead '96 Trident in NYC
Wire screen? Oil ain't gonna matter much with that...
You sure they don't have foam or paper or cotton under the wire?
Cheers,
-Kit
KitNYC is online now   Reply With Quote
Old 09-06-2009, 06:02 PM   #3 (permalink)
Favourite Bike: 04 Bonnie black
If they are like these,I run my dry.
Old 09-07-2009, 12:50 PM   #4 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
As Kit pointed out, it depends on what filter material is behind the screen, if any (which I argue is needed). If it is paper or a cotton-type material, use nothing. If it is foam, I would definitely use an air filter oil, as the filtering ability is highly improved over a dry filter.
I recommend getting a can of PJ1 air filter oil spray, and maybe even their air filter cleaner spray for easy cleaning (you can get them online or in some Motorcycle shops). If you don't get the cleaner, use a Simple Green type solution and clean and oil the filter at every motor oil change (or more frequently if you live in a dusty region).
The Resurrection: ’02 CE Speedtona w/GSXR Forks
The Reviving: Speed-TT Project
"When I reflect upon the number of disagreeable people who I know have gone to a better world, I am moved to lead a different life." - Pudd'nhead Wilson
BombFactory is offline   Reply With Quote
Old 09-07-2009, 03:10 PM   #5 (permalink)
Newbie
the filters look as its just wire mesh folded waffer stile forming a cone shape that pushes up on the carb and clamped with hose clamp you can see light through the wire.
Old 09-07-2009, 03:40 PM   #6 (permalink)
If it is just a mesh screen, it isn't a proper filter. Although I've seen people running such 'filters', the only things they will filter out are leaves, rocks, large bugs, etc; however, all the dust, small bugs, or any other small debris will go straight into the engine, damaging the cylinder walls, bearings, journals, and all sorts of other stuff. If I were you, I'd be looking for a piece of filter foam to back the mesh.
After market Air-filters T-Bird panzaa Hinckley Classic Triples 0 07-06-2009 05:28 AM
After Market CTCruiser The Rocket Science Forum 10 05-30-2009 11:54 PM
after market parts jwnewell Triumph SuperSports 3 08-14-2007 01:33 PM
Target market stinebiz Twins Talk 34 12-09-2005 04:03 PM
GPS- I'm in the market for one UK-SPD Sprint Forum 16 03-24-2005 10:59 AM
