Custom David Bird Triumph Oil In Frame OIF Weld-On Motorcycle Hardtail Frame - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-17-2009, 01:50 PM   #1 (permalink)
Site Sponsor
Favourite Bike: '67 BSA Lightning chop
lowbrowcustoms's Avatar
Other Motorcycle: '53 Triumph Terrier
Extra Motorcycle: '61 Triumph T110 pre unit
Custom David Bird Triumph Oil In Frame OIF Weld-On Hardtail Frame
Custom-made weld-on David Bird hardtails for Oil In Frame (OIF) Triumph's are now available! These BSA hardtails are made from 1.25" x .125" wall crew tubing with 5/16" thick axle plates. Beautiful TIG welds, MIG welded axle plates. The axle plate slots are 5/8", set up for your stock OIF Triumph rear wheel. You aren't going to find a nicer hard tail anywhere.
The bottom hardtail rails have slugs that insert inside your stock frame rails. This locates it correctly, and the top rails are a tight fit against the stock frame. You get it in position and hit it with a deadblow hammer to get it in the correct position. The sheet metal plates provided finish off the bottom of the seat post tube perfectly.
Check out more info on the website here.
www.lowbrowcustoms.com
Join the Lowbrow Customs e-newsletter for weekly tech articles, new product info, and a chance to win cool parts and apparel!
lowbrowcustoms is offline   Reply With Quote
Old 04-09-2010, 02:43 AM   #2 (permalink)
Favourite Bike: Triumph TR6
-Pod-'s Avatar
Other Motorcycle: 1975 Honda CB 550
Ah yes, this is the one i'll be getting this summer for next winters hardtail project!
-Pod- is offline   Reply With Quote
Custom Frame oldsquid Speed Triple Forum 0 05-30-2009 10:19 PM
custom frame registration vicroads blacktop RAT - Australia 0 05-17-2009 08:41 PM
2001 Legend frame V. 2002 T-Bird Frame?? jonathanrsr Hinckley Classic Triples 1 11-27-2008 10:26 AM
T-bird frame condition Eggman Classic, Vintage & Veteran 2 10-18-2007 04:30 PM
frame blanks for frame / swing arm on 1050 ST PeirreOBollox Sprint Forum 0 03-11-2007 09:41 AM
