BSA Tapered Roller Bearing Conversion Kit to fit 1" HD or springer front ends - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-17-2009, 01:45 PM   #1 (permalink)
Site Sponsor
Favourite Bike: '67 BSA Lightning chop
lowbrowcustoms's Avatar
Other Motorcycle: '53 Triumph Terrier
Extra Motorcycle: '61 Triumph T110 pre unit
BSA Harley Neck Bearing Conversion - Fit a HD or Springer front end to your BSA
New from Lowbrow Customs, this tapered roller bearing conversion kit allows you to directly mount a Harley Davidson or Springer front end to your BSA A50 or A65 motorcycle. Kit includes two races, two Timken bearings, and a chrome dust shield. This kit will allow you to mount any front end with a 1" stem, including front ends from:
Harley Davidson Big Twins 1949 and newer
Sportsters 1982 and newer
DNA Springers or other Springers with 1" stems
Simply use a drift and hammer to drive out the old bearing races from your frame's neck, and tap these new races into place. The bearing with the dust shield goes on top and the other on bottom. That is it, simple!
www.lowbrowcustoms.com
Join the Lowbrow Customs e-newsletter for weekly tech articles, new product info, and a chance to win cool parts and apparel!
lowbrowcustoms is offline   Reply With Quote
18" or 17" front conversion on Bonneville??? duckboy Twins Technical Talk 17 01-10-2011 12:02 PM
Springer Front ends SbGunslinger Twins Talk 36 10-13-2009 09:18 PM
Roller Bearing Main thirdbike Classic, Vintage & Veteran 22 03-26-2009 03:39 PM
Tapered roller steering stem bearings vertwrks Twins Technical Talk 15 03-25-2008 11:06 AM
Springer Front Ends erikmustride Maintenance & Workshop Talk 18 12-12-2007 09:40 PM
