BikeBandit
Old 04-26-2005   #1 (permalink)
Andyman
Anybody know if the Reserve tank "communicates" with the Main fuel tank? In other words, if I always filled up before swiching to the reserve tank, would that mean that the fuel in the reserve tank is older than the fuel in the main tank, or do they mix?
Thanks,
Andy
Old 04-26-2005   #2 (permalink)
Favorite Bike: 1998 Thubderbird Sport
idahotb's Avatar
Other Motorcycle: 1996 Sprint
Extra Motorcycle: 1997 T595 Daytona
Andy-
It's all the same tank. The fuel tap draws from different depths depending on the tap postion. It has been recommended that you run the bike on reserve periodically to "clean out the sump" where any water/particulates accumulate, but the gas there doesn't go stale.
Speed is good. It is way better to be shot out of a cannon, than squeezed out of a tube. That is why God made motorcyles.
My album
idahotb is offline   Reply With Quote
Old 04-26-2005   #3 (permalink)
Andy;
They definately do mix. It is one big tank with two different length tubes that stick up into the tank from the petcock. The longer tube would be your "main" tank. Once the gas level gets below the top of the long tube, you switch the lever over and you are now on the short tube or "reserve".
John
LITTLEJOHN is offline   Reply With Quote
Old 04-26-2005   #4 (permalink)
Andyman
Gotcha - Thanks for the explanations!
Andy
Reserve Fuel LoVel Twins Technical Talk 16 06-04-2007 04:01 PM
Regular fuel tank vs. reserve tank question Newbritrider Twins Technical Talk 14 03-30-2007 03:53 PM
Fuel reserve Fraederichs Twins Talk 1 10-31-2005 02:53 PM
Fuel reserve on a TT? Triumph SuperSports 2 07-27-2004 03:49 PM
Fuel light and reserve tank kaosj Daytona Deliberations 6 05-08-2004 06:47 PM
