Called my dealer and asked about the rubbers. He could only find one set for the TBS but several for the t-bird depending on year and so on. Now I know that the t-bird went from Mikuni to Keihin...what about the TBS? Did they stick with the same? Which one in that case? Does it matter? Will the rubber with no matter if its a mikuni or keihin?
The first thing is to determine if you've got the restricted carb rubbers. They were only installed on the Mikuni carbs, so if you've got Keihins you don't need to change anything.
To double check, look for dimples in the sides of the carb rubbers about the diameter of a cigarette. If there are no dimples, you don't have the restricted carb rubbers.
The carb rubbers for the Mikuni and Keihin carbs are supposed to be slightly different lengths and diameters, so it's probably a good idea not to mix from one carb type to the other. (Haven't checked that personally.)
I believe it was the Super3 or Speed3 that used the unrestricted rubbers so have your dealer check on those for the same year of your bike.
Also, the dimple might be shown in the fiche or computer, but I'm not certain of that.
Jim
