Cost of running a trickle charger? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 21 (permalink) Old 10-16-2008, 09:59 PM Thread Starter
Main Motorcycle: 99 Legend TT
GrvThang's Avatar
This is so petty, it's laughable - the building cooperative where I live in NYC (a 'co-op' is similar to a condo, but you don't receive a deed) wants to charge me for the electricity that I use when I hook a trickle charger up to my bike during winter storage. I would imagine that the cost would be negligible.
Is there an electrical engineer (or other smart person) who can guesstimate how much electricity a 1.5 amp charger would use in a month to keep a motorcycle battery charged?
GrvThang is offline
post #2 of 21 (permalink) Old 10-16-2008, 10:06 PM
Newbie
Main Motorcycle: 04 Speedmaster
Other Motorcycle: 81 CB750
Your right about petty!
How about pulling the battery and put in a closet with your trickle charger on it?
I am not smart enough to guess how much it would cost other wise.
Speedmaster04 is offline
post #3 of 21 (permalink) Old 10-16-2008, 10:10 PM Thread Starter
GrvThang's Avatar
Speedmaster04, thalt's just what I plan on doing this winter! But get this - they want to charge me for doing this for the last 19 years!
GrvThang is offline
post #4 of 21 (permalink) Old 10-16-2008, 10:12 PM
Main Motorcycle: 2003 Speed Triple
Other Motorcycle: 1999 Legend
I hook my batteries (2)up to a trickle charger every winter alternating weeks on and off. I never noticed an increase in my electric bill.
What the Co-Op will charge you however
No quarter asked, none given
Gdsila is offline
post #5 of 21 (permalink) Old 10-16-2008, 10:20 PM
Newbie
Whoa!!!!
I'd move.............. course I am all talk, from Texas you know!
I can't wait to hear what they think it cost's them. I am sure it won't reflect reality, judging from the fact they are squakin about it.
post #6 of 21 (permalink) Old 10-16-2008, 10:42 PM
Send a message via AIM to CAPTDON
Smile Charger
A good laugh for me tonite!!! A trickle charger will use about as much as a 25 wat light bulb you left on! It its a on/off demand type charger that will be less. Sounds like where you live is feeling the $$ pinch rite now!! A battery tender will use MINIMAL elec !! $2/ mo??
If they are that desperate-put a solar panel in the sun & tell them to GO FISH? Thats really pinching pennies!! The govt says that a co-op/ condo CANNOT stop you from using ANY "green" energy devise! They CAN tell you where you can put it tho. I used to live in a condo & went thru some of this kinda crap!! Sat TV falls into that same thing. Good luck & thanks for the laugh!!
CAPT D
CAPTDON is offline
post #7 of 21 (permalink) Old 10-16-2008, 10:50 PM
Main Motorcycle: Black 06 Thruxton
Other Motorcycle: Black 09 FZ6
Well, assumig your not joking - here you go
Ok, at 80 percent efficience (which it isn't, more like 95 plus percent) and assuming a 1.5 amp continous ouput,
[1.5(amps) / .80] x 14.6 (volts) = 27.4 watts / hour = 0.0274 KW/ hour ==> 20.0 kwh per month.
Using 100 percent efficience:
[1.5(amps) / 1.00] x 14.6 (volts) = 21.9 watts / hour = .0219KW / hour ==> 16.0 kwh per month.
I don't know your KWH rate, but this should give you some insight into the cost, 1 to 3 dollars a month. About the same as two bright night lights.
Andy
Tusitala - Mt Vaea
SHILOH is offline
post #8 of 21 (permalink) Old 10-16-2008, 10:56 PM Thread Starter
GrvThang's Avatar
Thanks!
Thanks, Shiloh, for taking the time to run the equation, but wouldn't that be assuming that it's running (charging) all the time? The thing only clicks on when the charge dips below a certain amount. And maybe they want to figure in the cost of running the red, yellow and green LED's on the charger, too...
GrvThang is offline
post #9 of 21 (permalink) Old 10-16-2008, 11:04 PM
Yes, that's if it runs 7 by 24, but I did fail to take into account the LEDs. Wow, sorry about that gross oversight on my part, the LEDs will add maybe 5 or 10 cents a month.
Tusitala - Mt Vaea
SHILOH is offline
post #10 of 21 (permalink) Old 10-16-2008, 11:20 PM
357Bob's Avatar
Wouldn't a 1.5 amp. charger dry the battery out? Is it not a battery maintainer? Those things almost shut theirselves off when the battery doesn't need it. There are some solar cells that would set on the seat. It may need a bungee or something to hold it. But green & free & small. Bob.
357Bob
357Bob is online now
Cost of a non running T90 Pwfyrcat1 Classic, Vintage & Veteran 9 11-02-2007 04:52 AM
Trickle Charger & Adapter DEcosse Speed Triple Forum 2 04-06-2007 01:36 PM
Trickle Charger & Adapter DEcosse Daytona Deliberations 1 04-06-2007 12:57 PM
Best Trickle Charger to get? PA-guy Air Cooled Twins Talk 21 12-18-2005 09:38 PM
