Old 04-15-2005   #1 (permalink)
Hello all,
In the last 1000 miles on my 1996 Adventurer, I notice the Tachometer needle starting to "twitch" (500 rpm twitch typical) in the 3000 to 5000 rpm range. I figured it was time for a new cable, but couldn't seem to find any cable lead into the tach. Also I didn't see any cable lead from the engine (like my '82 Suzuki) to the instrument cluster. Is the Adventurer tach electronic? Yikes, if so I have no idea then why the tach is "twitchy". Thought it was an old tach cable that needed replacing.
Guess I'd better purchase a shop manual really soon, but thought I'd ask this forum first for advice.
Thanks, Daddy-O
How can you be in 2 places at once when you're not anywhere at all?
DaddyO-Dave is offline   Reply With Quote
Old 04-16-2005   #2 (permalink)
mecscc's Avatar
Hi, it is electronic. Try a search here for "tach" or "tachometer. Last year there were several threads on this issue. My mind is like a sieve so I can't remember exactly where to tell you to look, but I do remember the threads.
Monte
Monte
"The Old Ohio Preacher Man"
Old 04-16-2005   #3 (permalink)
Check for a bad ground connection in the headlamp housing. Suppose to be a common problem.
fbird is offline   Reply With Quote
Old 04-16-2005   #4 (permalink)
Favorite Bike: 98 Thunderbird
Mine got a bit twitchy a while back- it was the power wire at fault. It hooks up with 4 others inside the sleeving from the clocks to the headlight, and it is just a crimped joint.
I soldered the joint and it has been fine since.
Tachometer JKDJose Twins Technical Talk 2 04-16-2007 04:26 PM
Tachometer Adventure96 Hinckley Classic Triples 11 11-19-2006 09:16 AM
Need tachometer stu Twins Technical Talk 7 10-31-2006 02:46 PM
Tachometer Help Anchorbend Twins Talk 19 10-22-2005 02:08 AM
tachometer Blownfuse Classic, Vintage & Veteran 1 08-24-2005 12:39 PM
