changed plugs running now but still no fuel in center carb. trying to figure out how to pull air box to get to fuel rail maybe stuck float maybe trash?
If all three cylinders are firing (all pipes hot) then there's probably crud in the center float bowl preventing draining.
If the center pipe is cold and that cylinder not firing it would probably be a stuck float. Whack it with the big end of a screwdriver a couple of times and see if that fixes the problem before you start yanking things apart
I wouldn't suspect a clog in the fuel rail since the fuel enters between the #2 & #3 carbs, so if it was blocked your #1 carb would be dry too.
Jim
