Wonder if someone can end my confusion over this? I've seen a number of topics on this from people who obviously have a lot of knowledge of the T/bird, legend etc, saying that fitting after market cans alone does not require carb re-jetting, but ......
My 98 T/bird has the Triumph off-road cans (peashooters?). Since fitting I have developed pre-ignition at low revs/low throttle which higher octane fuel reduces but does not eliminate. Also my exhaust pipes have gone much bluer suggesting lean mixture or a timing problem? No other mods that would affect things, but I did change the plugs at the same time with the recommended part. Even under hard driving I am getting about 45-50 mpg (Imp gallons) or 9-10 mpl, which seems high from other members comments I have read.
Do I need to jet up or raise needles on the Keihin carbs? Or should I be looking elsewhere, eg timing?
Any suggestions appreciated.
Cheers :???:
nil illegitimo carborundum
