Trident-Exhausts.comAdvanstarMotorcycleShowsBikeBandit
ShopTriumph.com
Old 03-31-2005   #1 (permalink)
Has anyone heard of or used a 41 tooth sprocket, I'd like to
try one on my T-bird. I'm mostly on straight highway and wouldn't mind a little less rpm's.
Thanks
MH
mike_ is offline   Reply With Quote
Old 04-01-2005   #2 (permalink)
jimmyj900's Avatar
You might run out of chain clearance with a smaller rear sprocket and have the chain dragging on the swingarm.
A larger front sprocket would be a better idea. Aside from the clearance issue it would also wear longer.
The ratios between a 17:41 and 18:43 are pretty close, so it's worth looking at.
Jim
http://s279.photobucket.com/albums/k...0Head%20Stuff/
Old 04-01-2005   #3 (permalink)
I just put a 19tooth on the fron of my adventurer. At 75mph, the RPM's are down about 500. Not sure how good the milage is yet. One thing I have noticed is that I have more of buzzing in my handlebars that cause my hands to go numb. (not sure if it is related)
Acceleration will be a little slower.
Jason
'97 Adventurer
My Photos
jasmail is offline   Reply With Quote
Old 04-01-2005   #4 (permalink)
Thanks for the info.
MH
45 tooth sprocket oldyeller Daytona Deliberations 11 08-16-2007 03:16 PM
18 or 19 tooth sprocket ajf Twins Talk 34 03-31-2007 07:16 PM
18 Tooth Sprocket Bigman Twins Technical Talk 8 11-11-2006 05:43 PM
Tried th 19 tooth sprocket TTBONNE Twins Technical Talk 8 09-10-2006 12:45 PM
18 tooth sprocket $ clubman Sprint Forum 13 02-20-2005 01:08 PM
