Old 07-23-2008   #1 (permalink)
Newbie
Has anyone had this problem?!
Hi, i'm new to this but am the proud owner of a 1998 Triumph Thunderbird and thought it would be great to get involved.
Basically the bike hasnt been used for a while and now when it is started it pumps out lots of fumes and it is burning oil. Has anyone else had this problem and knows what may be wrong?
Im obviously not an expert so if its a stupid question please forgive me!!
Many thanks,
Marcus
mjmain7 is offline   Reply With Quote
Old 07-23-2008   #2 (permalink)
Favorite Bike: 1996 Adventurer
Other Motorcycle: 2000 DRZ400-S
Extra Motorcycle: 1982 KZ 750
If by "not been used in a while" you mean more than a year, I would start by removing the carbs and completely cleaning them. Then check the oil level, maybe rinse out the fuel tank, change all fuel fliters, the oil filter, and inspect the air filter... Any fluids in that bike are probably the cause of your problem unless it had been thoroughy abused in its previous life.
gregp is offline   Reply With Quote
Old 07-23-2008   #3 (permalink)
Newbie
Thanks Gregp,
The bike has had new oil filters fitted and I have cleaned the carbs etc. I have just found that there is no air filter in the air box (previous owner must have removed it). Why he did this I dont know, I have only owned the bike for a few months and it wasnt used for a year before I bought it. It burns oil quite badly, when I changed the oil there was only 2litres left in there.
Any ideas?
Cheers
Old 07-23-2008   #4 (permalink)
Favorite Bike: 2004 Thruxton
Other Motorcycle: 1997 Thunderbird
Extra Motorcycle: 1973 Norton
engine smokes
If the engine had been ran for a long period of time without the air filter element internal engine wear may have happened. Pull the plugs and look for oil fouling ,also do a compression test .
Tim
TTRIDER is offline   Reply With Quote
Old 07-23-2008   #5 (permalink)
I would guess that you may have significant piston/ring/bore wear or damage, probably caused by running with no air filter.
Sorry.
Old 07-23-2008   #6 (permalink)
Newbie
Hi Thanks Tim/greg, the plugs are fine and it hasnt done many miles without the filter. I will get a compression test done and hope it is the rings and not the pistons.
Cheers
Old 07-24-2008   #7 (permalink)
Favorite Bike: '04 Triumph TBS
cpallen's Avatar
Other Motorcycle: '05 BMW R1200 GS
Burning oil?
Beware there are two potential drain plugs - one does not drain all the oil and if you aren't watching the sight glass and just add 4 qts guess what - it will be overfilled and it will certainly be smoking and probably pumping out of the crankcase vent into the airbox, etc.
Read this:
http://www.webbikeworld.com/Motorcyc...soil.htm#drain
And let us know what you think.
Courtney in Seattle
Courtney
cpallen is offline   Reply With Quote
Old 07-25-2008   #8 (permalink)
Favorite Bike: 03 TBird
Other Motorcycle: OIF Bonnie
Check the oil for fuel odor. If the gas leaked down into the crankcase, and it can, then it could smoke when run. Speaking from experience.
Beemie is offline   Reply With Quote
Old 07-26-2008   #9 (permalink)
Favorite Bike: '98 Triumph Thunderbird
Tbirdnz's Avatar
Other Motorcycle: '05 Honda CB1300
Extra Motorcycle: '62 AJS 650 Twin
Might be jumping to conclusions here. As cpallen indicates there are two drain plugs and with one only a couple of litres drains out.
If you just bought the bike ? and it hadn't been used for a year it could be the previous owner stored it and poured a bit of oil down the cylinders, some people storing it long time do that.
There's no air filter in the air-box it's a separate unit between the air-box and the carbs.
Do the routine maintenance, change the plugs and start it up, run it for 5 minutes or so and see if the smoke clears away.
How many miles on the clock ?
Ride on !
Tbirdnz is offline   Reply With Quote
Old 08-02-2008   #10 (permalink)
cpallen's Avatar
Update?
Hey Marcus, have you made any progress on your oil issue?
Courtney
Do I have a problem? jdzorro Twins Technical Talk 1 04-28-2008 06:55 AM
Do I have a problem quagmire Classic, Vintage & Veteran 7 07-18-2007 10:37 AM
I had the same problem. etachell Speed Triple Forum 0 07-13-2007 10:39 AM
Problem with gas cap. anthonymelendez Twins Technical Talk 11 09-08-2006 10:03 PM
Gas cap problem runtheton Twins Talk 10 05-17-2006 11:33 AM
