Howdy P2me. Welcome aboard. Where is the chirping noise coming from specifically? And are you sure it's not more of a high pitch whine coming from the engine's topend? In my experience, chirping sounds usually indicate a leak in the intake gasket/rubbers. This is easy to check by spraying some carburetor cleaner in that area while the bike is running at idle. If you have a leak there, the RPM should change (usually go up). Some folks have actually experienced some pinhole leaks in the carb rubbers.
Otherwise, these engines do whine. Most folks equate the sound to an angry Singer sewing machine but I think mine sounded more like George Jetson's car (before I drilled out the mufflers). Either way, they are noisy engines - which is fine by me as long as it keeps running well.
Hopefully somebody else has some more ideas to contribute.
I only have two brain cells left...and they ain't speaking to each other.
