wheels and exhaust - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Motorcycle.comOntario TourismHonda PowersportsMotorcycle.com Classifieds!
Old 03-25-2005, 12:06 PM   #1 (permalink)
Sorry for the dumb question but I've only had the bike a week!
It's a 2003 Thunderbird sport, and I'm looking for some advice on keeping the wheels and exhausts looking good.
Are the wheels chromed steel or polished aluminium?
The exhausts look like chromed steel?
The handbook says not to use autosol or chrome polish!??
So whats the best thing to use?????.........................need to get it right cos I need to use the bike in winter to go to work??
Thanks, Pete :???: :???: :???:
Old 03-25-2005, 12:28 PM   #2 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
That depends upon the year - late ones were steel early ones aluminum. IIRC the changeover happened in late 1999.
Easy way to tell is with a magnet.
Aluminum wheel rims can be polished with steel wool and autosol to keep them looking at their best. This is all or nothing - if you do it one you have to keep on doing it as they will corrode faster once it has been done once.
[ This message was edited by: MickMaguire on 2005-03-25 10:32 ]
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 03-25-2005, 12:30 PM   #3 (permalink)
The exhaust are chromed stainless, the can rust a little at the interface between the metals, but if you keep them clean then they will retain their finish. Polishes such as autosol are never recomended by manufacturers for chrome as it is abrasive and will wear the chrome away over time.
Soap and water is the best thing - then use regualr car wax (such as turtle wax) to keep the chrome looking like new, and to protect it from the elements.
Mick...
Old 03-25-2005, 02:50 PM   #4 (permalink)
Pete,
i only use waxes for all my polishing, among the best are
Auto Glym, Meguiars NXT, Cristal Glo,
Auto Glym products are British made and are superb but i do'nt know if they are available in U.S.A. but Meguiars products are U.S. made and are very good indeed.
I personally choose whatever my mood takes me.
Hope this helps,
Gerry
Gerry is offline   Reply With Quote
Old 03-25-2005, 03:13 PM   #5 (permalink)
Favourite Bike: 1995 Thunderbird
SWare's Avatar
Another easy way to tell if you have alloys is they say Akront on the rim. On the alloys I have used never dull by eagle. As long as they are not corroded this will polish them up nicely. Since it is non abrasive you will not run into the problem Mick describes.
stan
SWare is offline   Reply With Quote
Old 03-25-2005, 03:19 PM   #6 (permalink)
Hi again Guys,
thanks for the info!.....................
have tried a magnet on the wheels AND the exhaust, they're definately steel, could it be a case of chromed steel on a uk bike??
Will use soap and water and Autoglym, and leave the bike at home when the roads have been salted!!
Old 03-25-2005, 04:18 PM   #7 (permalink)
sorry, yes the exhaust is steel, the exhaust headers are stainless.
the last bit about salted roads is the single best thing you can do to extend the longevity of a bike's finish.
Mick...
Old 03-25-2005, 10:34 PM   #8 (permalink)
jimmyj900's Avatar
I think the question of chromed stainless vs. chromed mild steel may vary by the model and year.
The pipes on my 2K Adventurer seem to be steel since I was able to weld a steel fitting into the pipes with a mild-steel wire in my welder.
Jim
Old 03-25-2005, 10:54 PM   #9 (permalink)
it's pretty easy to tell if they are stainless - a magnet wont stick to stainless very well if at all.
Mick...
Old 03-26-2005, 12:25 PM   #10 (permalink)
DAGAD's Avatar
The stainless used on the header pipes is only 303 Grade and can be slightly magnetic.
Regardless of this, good advice from the other guys. Soap and water, followed by Auto glym.
Scott oiler do a 'salt neutralizing' all year round spray called FS365, and comes in 1litre trigger sprays. I have used it for the first time from the end of '04 on my bikes and am well pleased. Check out Scottoiler web site. Roy
Carrozzeria Wheels vs wire wheels MAR Club Cafe' 8 12-17-2008 03:36 PM
Wheels rickster Daytona Deliberations 3 06-28-2007 02:21 AM
Wheels Buckadoosa Twins Technical Talk 1 09-15-2006 11:05 AM
Old/New ST Wheels pushr0d Sprint Forum 3 06-30-2005 12:09 AM
Wheels Triumph SuperSports 8 05-06-2004 12:15 AM
