Originally Posted by Mag00
BTW, what is the correct routing for the fuel hose from the petcock to the carbs? My Adventurer has just the single fuel line hooking up between carbs 2 and 3.
That's correct.
Reading over the posts so far, it's time to go back to the beginning.
The first issue was the carbs being way out of balance with a really high vacuum on #3 (the right one) followed by a rough idle that won't smooth out now that they're balanced.
Is that correct so far?
The second issue is weak operation over about 4K or so.
When the bike is running weak, do you get any misfiring? Does the sound of the exhaust get sharper or duller?
How many miles are on the bike?
Jim
