High beam, water temp, neutral lights won't come on. Oil pressure light ok...
If some dungforbrains tried to do the temp lite fix and screwed it up, then there should be a 'strange' wire that's either loose from the main bundle, tie-wrapped fast or taped to the main wiring bundle. That wire should go to a ground point on the chassis, possibly near the steering head.
Try and locate that first. You may have to remove the gas tank to find out where it goes and/or identify it.
Follow that wire back to the connectors in the headlight. If dungforbrains was capable of some coherent thought, that wire should connect to the black/yellow wire on the bike side of the instrument cable connector. If it jumps over the connector and hooks to the instrument wiring bundle then that's where the problem is.
There are multiple splices in the ground leads of the lamps inside the instrument harness and no telling what dungforbrains did to the wiring, so this may take some time.
Let me know where the strange wire goes -- to the instrument wire bundle or the main wire bundle.
Jim
