03-21-2005, 04:07 PM
Powerbike Favourite Bike: '99 Legend Frankenbike
Posts: 392 Other Motorcycle: Wife won't let me!
Does anyone know if there is a fork brace available for the classics? I know Norman Hyde makes one for the new Bonnie...
"Creag an Sgairbh"
'99 SpeedLegendRetroCafeFighter:
ZX12R USD Forks : Custom 3-1 exhaust : FactoryPro jet kit : Speed Triple cams : Pod filters : ZX9R shock : 5.5" rear wheel : Customized seat : FEK : SPA speedo/tacho : Pazzos
03-21-2005, 04:58 PM
I emailed Bellacorse to see if their Bonnie one would fit. No answer so far.
2000 TBS Cafe Racer :: 2000 Frankenmille
03-21-2005, 05:19 PM
Site Supporter Pole Position Favourite Bike: Well, Duh!
Posts: 3,650 Other Motorcycle: Can't afford two! Extra Motorcycle: Three would be insane
One for a ZRX1200R would likely fit quite nicely (there are people selling them at ZRXOA.org) as the fork spacing is the same and the Triumph fork protectors fit the ZRX legs like they were made for them.
that center piece can be flipped over (so you can lose the 1200 stamp) and they are available in black or brushed aluminum (which would probably look best on a TBird) IIRC
It seems very unlikely that the Bonnie ones would be of the required dimensions.
[ This message was edited by: MickMaguire on 2005-03-24 09:18 ]
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
03-21-2005, 05:26 PM
Site Supporter Moto Grand Prix Favourite Bike: '98 Thunderbird Sport
Posts: 2,585 Other Motorcycle: '06 Husqvarna TE 610 Extra Motorcycle: '95 TBird - Project
So if this were used it looks like the Triumph fork protectors could not be used also.
Is that correct?
Cheers,Denny
03-21-2005, 05:46 PM
Correct
There is also a different one avaialble on the ZRX board that has built in fork protectors too - but not as cool looking IMHO
Mick...
03-21-2005, 05:47 PM
I measured up my ZRX and Thunderbird forks for comparison:
The ZRX fork legs are 65mm in diameter at the brace mounting point. The Thunderbird is 64mm. Thereofre there would be a need for a 0.5mm thick shim material around each fork leg (suggest rubber or similar). Most importantly it means that this brace could easily be made to fit.
The distance between the centers of the fork legs is identical.
[ This message was edited by: MickMaguire on 2005-03-21 18:47 ]
Mick...
03-22-2005, 12:09 AM
Is that correct?
On second thoughts Denny, I think that on a TBird you may have room to fit the guards too. You have to remove them on the ZRX as this bolts clamps to the area where the guards mount. However, with the Thunderird you woudl only be limited by how far you could slide them down without hitting the mudguard. I have a suspicion that there may be enough room for both.
I also have a feeling that these may work on other T3 models too.
[ This message was edited by: MickMaguire on 2005-03-22 07:46 ]
Mick...
03-22-2005, 09:49 AM
Here's the page for contact info for the guy that makes/sells these (no affliation BTW). The page has some other goodies of interest too including an oil filter cover with drain plug that looks like it might work on a Thunderbird.
CLick Here for the page on ZRXOA.org
Mick...
03-22-2005, 11:00 AM
On 2005-03-21 15:47, MickMaguire wrote:
IThe distance between the centers of the fork legs is identical.
I would think that it should if you used your stock triple clamps.
03-22-2005, 01:34 PM
Good to know - thanks for the info Mick!
"Creag an Sgairbh"
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Fork Brace, is there one ?
BorgCymru |
Twins Technical Talk |
10 |
11-05-2007 12:31 PM |
Fork Brace
rbrian_taylor |
Club Cafe' |
16 |
02-22-2007 03:18 PM |
NH Fork Brace
Jam |
Twins Talk |
3 |
05-17-2006 08:26 PM |
Fork brace?
Anchorbend |
Twins Talk |
2 |
11-08-2005 07:05 AM |
Fork Brace
tyrebyter |
Tiger Mods & Bolt-Ons (archive) |
9 |
09-02-2005 04:29 PM |
