Electrical Starting Problems - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 27 (permalink) Old 06-03-2008, 11:55 PM Thread Starter
Main Motorcycle: Mutato -- 2K Adventurer
jimmyj900's Avatar
I figured I'd put up a list of starting symptoms since they're pretty common, along with some troubleshooting and PM tips.
Copy this and stick it in a file somewhere. It might become useful all of a sudden.
Starting System Symptoms:
Weak battery symptoms:
-- Slow cranking.
-- Stops cranking suddenly on compression stroke with button pressed.
-- Starts when starter button is released at end of cranking.
Repair:
-- Charge/Test/Replace battery.
Failure Modes:
-- Loss of capacity. Appears to charge, voltage good but no reserve for starting.
-- Won't hold a charge.
-- Low voltage/cell failure.
Preventative Maintenance:
-- Check fluid levels regularly
-- Maintain full charge: Regular riding, trickle charger.
Ignition Coil failure symptoms:
-- Hard starting/misfiring during cranking.
-- Rough idle that can't be tuned out with carb adjustments and carb cleaning.
-- Idle misfire clears with new sparkplugs, returns in a few hundred miles
Repair:
-- Replace: Preferably with Nology for higher reliability than stock Gill coils.
Failure Mode:
-- Shorted turns in secondary resulting in weak spark.
-- None
Testing:
Pickup Coil failure symptoms:
-- No spark at all
-- Spark quits with engine hot, returns when engine cool.
-- Note: Pickup coil failure is total. There is no random misfire spark loss.
Repair:
-- Replace pickup coil
Failure mode:
-- Thermal intermittant with long (15-30 minute) period.
-- None. Get a spare.
Testing:
-- Ohms checks hot and cold.
Worn starter symptoms:
-- Sometimes won't crank until the bike is rocked in gear.
-- Excessively noisy cranking with a grinding sound.
-- Click from under seat but no cranking.
Failure Mode:
-- Brush wear progressing to commutator damage.
-- Bearing failure related to brush wear.
Repair:
-- Rebuild or replace.
-- Maintan battery in peak condition.
-- Follow proper starting procedures. Neutral, clutch in.
-- Crank 5-10 seconds at a time max., switch off for twice as long before cranking again.
Worn sprag clutch symptoms:
-- Very loud rattling when cranking
-- Starter spins but engine doesn't turn
Falure Mode:
-- Breakage
Repair:
-- Replace sprag clutch
-- Maintain battery in peak condition.
Worn starter solenoid:
-- Won't crank after rocking bike.
-- Starter continues to run after bike starts and won't stop until the battery is disconnected.
Failure mode:
-- Internal contact damage resulting in non-conduction.
-- Internal contact damage resulting in contacts welding shut.
-- Internal damage/wear prevents solenoid core movement.
-- None.
Repair:
-- Replace starter solenoid.
Testing:
-- For no cranking, short across solenoid high-power terminals. Normal operation denotes failed solenoid contacts.
Please free to comment, make suggestions, etc.
Jim
jimmyj900 is offline
post #2 of 27 (permalink) Old 06-04-2008, 01:33 AM
Main Motorcycle: 2012 800 Tiger
lovecuba's Avatar
Other Motorcycle: 1977 T140
Well done Jim. Have copied and printed for future reference. Still a tad bemused though with this holding in of the clutch lever when starting. This is so good if the bike has been running and the engine hot. For cold starts though achieves absolutely nothing as the clutch plates are firmly stuck together. In this case when the starter button is pressed it is up to the starter motor to overcome and separate these plates and it takes quite a lot of energy ( with the clutch lever held in ). Even during Summer an overnight 'sit' will cause the clutch plates to stick together. To alleviate this additional strain on the starting system, and I realise it is 2008, I revert back to the tried and true, as we did in our 'kick start' days to free the clutch and save the gearbox mainshaft from stress when engaging 1st gear. In those days it was a matter of holding in the clutch when in neutral and jumping on the kick start. This prevented the bike, when running, of lurching forward when placed in 1st gear. Now we put bike is 1st gear, hold clutch in, then rock bike backwards and forwards until resistance is broken from stuck clutch plates. This takes quiet a lot of human energy so imagine how our puny starter motor feels when undertaking this chore. Then press button A all the starter motor is then turning over is the crankshaft as the drive to the gearbox has been 'broken'.
lovecuba is offline
post #3 of 27 (permalink) Old 06-04-2008, 03:11 AM
Main Motorcycle: 98 Adventurer
Other Motorcycle: 1980 kz 650 kawasaki
Extra Motorcycle: 1999 kaw Concours
Thanks, Jim
Bbogie is offline
post #4 of 27 (permalink) Old 06-04-2008, 04:35 AM
Main Motorcycle: 2000 Thunderbird
Other Motorcycle: Wishing for MI3 Scrambler
Thanks, great thread. You've been a lot of help.
Might though put a section on the !@#$&* igniter though.
Kittlemeier is offline
post #5 of 27 (permalink) Old 06-04-2008, 08:48 AM
Main Motorcycle: 1995 Thunderbird
triumphjan's Avatar
Other Motorcycle: Thunderbird Sport 1998
Extra Motorcycle: Estrella BMW R 26
Thanks Jim,
Please free to comment, make suggestions, etc. Jim
The bike dos nothing at all complet dead, look the main Fuse.
and other fuse.
Cheers jan.
triumphjan is offline
post #6 of 27 (permalink) Old 06-04-2008, 10:06 PM Thread Starter
jimmyj900's Avatar
I can tell you it's microcontroller based, that the 'dwell time' for the coils is between 0.002 and 0.004 seconds which makes it rather difficult to measure with a DVM and a bunch of other stuff I can't think of at the moment.
I've spent the last two weeks (while waiting for my front brake pads to come in) learning microcontrollers and assembly programming, doing rudimentary electronic interface designs, researching available information and doing timing diagrams while attempting to develop the necessary ignition control algorithms to implement a system.
So what do you want to know?
Jim
post #7 of 27 (permalink) Old 06-04-2008, 10:08 PM Thread Starter
jimmyj900's Avatar
Originally Posted by triumphjan View Post
The bike dos nothing at all complet dead, look the main Fuse. and other fuse.
You've got another problem somewhere if either of those fuses opens.
Look for a wire with damaged insulation -- probably in the headlight area or in the red wire to the coils.
Jim
post #8 of 27 (permalink) Old 06-04-2008, 11:39 PM
Main Motorcycle: 1996 Thunderbird "Nessie"
cafetbird's Avatar
Other Motorcycle: 1973 Trump TR7RV "Loosie"
Extra Motorcycle: 1996 Triumph Super III
Thanks Jim,
and other fuse.
Cheers jan.
Also, if nothing happens, check your sidestand switch and your clutch switch. Failure mode - corrosion in switch. You can clean them with contact cleaner and regrease with dielectric grease. I know from experience that the clutch switch is very servicable - haven't had to fool with the sidestand switch yet...
Scot Dail, IBA #31553; 59 Club #29906
"Thunderbirds are GOOOOOOOO!"
cafetbird is offline
post #9 of 27 (permalink) Old 06-04-2008, 11:48 PM
Legend
Main Motorcycle: '98 Triumph Thunderbird
Tbirdnz's Avatar
Other Motorcycle: '05 Honda CB1300
This might be actually better in a blog Jim where we can add other types of faults to it but for now we'll make it a sticky on the forum. Saves searching.
Ride on !
Tbirdnz is offline
post #10 of 27 (permalink) Old 06-05-2008, 02:04 AM
Jim
What was the middle thing?
big problems with electrical? HELP PLS rider955i Maintenance & Workshop Talk 8 03-17-2008 07:10 AM
S4 Electrical Problems showmetheway428 Triumph SuperSports 13 10-20-2007 10:18 AM
Electrical/Starting Problem svanos Hinckley Classic Triples 9 12-31-2006 08:37 PM
Electrical problems Loebie Speed Triple Forum 1 10-04-2005 03:09 PM
Electrical problems- help Sprint Forum 8 04-11-2004 03:07 PM
