Pulled the rear wheel off. Got a question. - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGearHonda Powersports
Old 03-18-2005, 08:38 PM   #1 (permalink)
Is the sprocket/sprocekt coupling supposed to just come right off the wheel when you remove it from the bike?
I have the haynes manual, but it is kind of vague in the tire removal area. This is the first time I have removed a wheel from a motorcycle.
I am taking it tomorrow to get a new tire.
While I've got you here, should I do anything to "break in" the tire before I re-install it in the bike. I was thinking sandpaper, maybe with the orbital sander to scuff it up a bit.
Thanks
wabbit
00wabbit is offline   Reply With Quote
Old 03-18-2005, 08:57 PM   #2 (permalink)
triple4power
The sprocket comes away from the wheel with the piece that it is bolted to (Sprocket Coupling). Inside the wheel you will see a round rubber piece (Damper) you need to remove this and any spacers or stuff that could fall out and be lost.
Paul
Old 03-18-2005, 08:58 PM   #3 (permalink)
Favourite Bike: 03 Stone Touring
TexasTri's Avatar
Other Motorcycle: 00 Legend
Extra Motorcycle: 72 DT250
Wabbit,
Perfectly normal for that to come off, check the runner 'cushions' inside to make sure they are in OK shape. As for breaking in a tire you should just take it easy for about the first 100 - 150 miles. Not hooliganism. after that you should be fine.
Russ,
TexasTri is offline   Reply With Quote
Old 03-18-2005, 09:02 PM   #4 (permalink)
Thanks.
Old 03-19-2005, 05:33 AM   #5 (permalink)
Put a little dab of grease on the rubber cushions to hold them in place for reassembly.
Bob
My Photo Album
bobshields55 is offline   Reply With Quote
Rear wheel question quagmire Classic, Vintage & Veteran 2 03-25-2007 08:45 PM
Anyone pulled their wheel bearings ? Normandy Twins Technical Talk 10 11-15-2006 09:57 PM
easy rear wheel question internetay Classic, Vintage & Veteran 2 05-26-2006 09:42 AM
Question about 1050 rear wheel nut spacers Martin_R Speed Triple Forum 4 03-11-2006 05:01 AM
HELP...rear wheel/chain adj.question...HELP dietDrThunder Maintenance & Workshop Talk 26 09-22-2003 10:33 AM
