96 Adventurer ticking noise
Okay, listen to my Cafeturer one day and I think it´s time to check valve clearanses.
Check all valves thorougness and they are all in specs.
I´m little worry about this thicking sound and I think it´s better to inspect also cam chain /chain tensioner.
Remove a tensioner, check spring etc. and put it back. Pulling lightly that plunger to contact with the tensioned blade, IT´S COME OUT WHOLE LENGHT (you can see that above when valve cover is removed) before chain is tight.
What that means, is it possible that cam chain is so stretched or tensioned blade is worn-out. Bike has only 13000km on clock, runs really fine, but that NOISE ? !
Yes, I know these bikes are noisy but this is different and more than before.
Reason: fix spelling mistakes (but not all) ;-)
