chain and sprocket question - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comOntario TourismMotorcycle.com Classifieds!New BonnevilleHonda Powersports
Old 03-18-2005, 06:41 AM   #1 (permalink)
Stupid question for you guys. I'm new to bikes and was looking to replace the chain on my 99TBS. The question is, do I have to replace the sprockets as well, they look pretty good but the chain is getting to the end of the adjustment marks(currently has 14,500miles). Don't have a lot of money to spend and would prefer not to have to buy sprockets if I don't need to. Any advice would be very much appreciated Thanks Fbird
99TBS and 2000 Sprint ST
fbird is offline   Reply With Quote
Old 03-18-2005, 07:08 AM   #2 (permalink)
It's difficult to say, really. My experience is that the back sprocket wears out sooner than the front sprocket. But you never know 'til you actually examine it.
My advice is to do a complete change. That way the chain and sprockets will wear evenly. A slightly worn sprocket can take a lot of miles out of a new chain in a short period of time.
It's not THAT expencive, is it?
T'Weed
The future's so bright, I gotta wear shades
Tumbleweed is offline   Reply With Quote
Old 03-18-2005, 07:49 AM   #3 (permalink)
jimmyj900's Avatar
Gotta agree with Tumbleweed on that.
Replacing the chain and not the sprockets will accelerate chain wear and make adjustment more difficult.
And, of course, an improperly adjusted chain wears faster.
If it's a matter of cost then a chain and sprocket set is a lot cheaper than two chains and a set of sprockets...
Jim
Old 03-18-2005, 08:15 AM   #4 (permalink)
Slinky's Avatar
You really need to look at the sprockets and decide how worn the teeth are.
Most wear takes place on one edge of the sprocket teeth (leading edge on the front, trailing edge on the rear). If the sprockets are suitable you can turn them around and use them again.
If you want to save money in the short term, you could always buy a cheap chain for now and replace the whole lot later on.
Old 03-18-2005, 09:42 AM   #5 (permalink)
If you're sprockets are fine, it is okay to replace the chain and not the sprocket. I know it is recommended to replace both, but I've never went with this theory. I currently have 30,000 miles on my TBS with the stock sprockets and am on the second chain...
Dave Arnold
'04 Rocket III
'00 Trophy 1200
La Vernia, TX
tbsrider2000 is offline   Reply With Quote
Old 03-18-2005, 10:05 AM   #6 (permalink)
Favourite Bike: 1995 Thunderbird
SWare's Avatar
I would replace both unless money is really tight.
As Slinky suggests you could get away with replacing only the chain if the sprockets don't look too bad.
stan
SWare is offline   Reply With Quote
Old 03-18-2005, 11:46 AM   #7 (permalink)
Favourite Bike: '98 Thunderbird Sport
denny's Avatar
Other Motorcycle: '06 Husqvarna TE 610
Extra Motorcycle: '95 TBird - Project
The sprockets on our classic triples cannot be turned over and used that way.
Take a close look at the rear one and you will see why.
If you turn it over the sprockets will not be aligned properly.
Cheers,Denny
denny is online now   Reply With Quote
Old 03-18-2005, 10:23 PM   #8 (permalink)
Wow!! Wasn't expecting this many replies. Thanks very much for all of your input. Sounds like I need to just wait and replace the sprockets just to be safe. If any thing it's an excuse to go with a larger sprocket in the rear, give me a little more acceleration. Thanks again. Fbird
Old 03-30-2005, 02:31 PM   #9 (permalink)
Check what is the brand of your chain..
Some Triumph have been mounted with weak Regina chain
Some other with more satisfaying DID ...
legend21 is offline   Reply With Quote
chain/sprocket combo fergman Sprint Forum 7 02-01-2008 07:47 PM
new sprocket, new chain? metasac Twins Technical Talk 14 09-22-2007 02:14 AM
chain and sprocket changing oldyeller Daytona Deliberations 7 11-11-2006 03:07 AM
chain/sprocket life MilwFreddy Trophy 3 03-19-2005 04:19 PM
after mkt chain and sprocket question Hinckley Classic Triples 9 12-02-2004 06:51 PM
