Site Supporter Pole Position Favourite Bike: Well, Duh!
Posts: 3,650 Other Motorcycle: Can't afford two! Extra Motorcycle: Three would be insane
Where exactly is the leak coming from - I take it you have replaced the float bowl seal?
If it's not from that seal (actually even if it is) it's possible that either your float valves are worn or you are getting dirt/rust down from the tank and blocking them open. Either way you should clean out the tank and carbs and add a fuel filter.
Wear seems unlikely at the milage, but tank rust seems very likely - this bike has sat around a lot.
[ This message was edited by: MickMaguire on 2005-03-17 09:21 ]
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
