BikeBandit
Old 05-21-2008   #1 (permalink)
Favorite Bike: 2003 Thunderbird Black
musicisinmysoul's Avatar
Other Motorcycle: Bonneville T100 Red/Black
Extra Motorcycle: Fancy a Classic
Oil (again)
I know this has been covered before but for any new members who are about to do an oil change be carefull, the book says 4ltrs, I left my drainining for a whole week (the washers where missing when I removed the filter, the last person to do an oil change was Roberts Triumph in Yorkshire, bit naughty guys leaving the washers out) anyway it still only took 3.25ltrs and even then it was over the glass viewer.
And she'll have fun fun fun till her daddy takes the T-Bird away!
musicisinmysoul is offline   Reply With Quote
Old 05-21-2008   #2 (permalink)
Favorite Bike: 95 TBIRD
patrol21's Avatar
Check out the threads on this. There are 2 drains plugs.....sounds like you drained using the one closer to the center. Take a look under the bike..you will see a 2nd drain plug closer to the side stand.
The worst day riding beats the best day at work....no exceptions.
patrol21 is offline   Reply With Quote
Old 05-21-2008   #3 (permalink)
Favorite Bike: 1996 Adventurer
Other Motorcycle: 2000 DRZ400-S
Extra Motorcycle: 1982 KZ 750
I just did an oil change on my Adventurer and I was surprised to find not 1, not 2, but 3 oil plugs! The 3rd was right behind the oil filter, which does absolutely no good if you find it after you have already removed the filter.....;-)
Greg
gregp is offline   Reply With Quote
Old 05-22-2008   #4 (permalink)
Greg
I thought on the later models (mines an 03) that there was just the one plug?
Old 05-22-2008   #5 (permalink)
Hmmm, Take a close look under your bike and let us know. I have two plugs in a horizontal orientation and one vertical. Look carefully! I didn't even see the one behind the oil filter until I had changed the oil several times.
The first time that I changed my oil, I was wondering why the oil turned dark right away. I did not see the second plug and left about a pint of old oil in the case.
Old 05-22-2008   #6 (permalink)
nope, just the one drain plug Greg.
