Old 05-18-2008   #1 (permalink)
Favorite Bike: 01 Legend TT
RIRAT's Avatar
Other Motorcycle: Does a BMW Z3 count?
TBS Handlebar risers for a Legend ??
Hello all,
I have another question regarding my neverending set up on my Legend TT. I did do a search but didnt find anything similiar. Maybe I missed something.
3 facts:
I have the TBS bars on mine for a cafe racer look.
The ride gets uncomfortable after an hour or so due to my excessive leaning on the bars. Basically the neck gets sore from looking up and the inside of my hands between my thumb and fingers get sore from me using the bars as partial support.
This gets worse when the mrs comes along and braking pushes her into me making the low stance on the bars even worse.
I do love the looks but I have to say, its not incredibly practical. Ive had the bike for about a month and a half and have already racked up 1500 miles so i do some long, all day trips.
What Id like to do is keep the TBS bars and bring them up to my level a little. I looked into thunderbird sport risers but the dealer tells me the yoke is different on the two bikes and whether they fit is a crapshoot. Im not concerned with pulling them back towards me because due to the angle on the forks, straight risers will pull them back a little anyways. Does anyone know where I can get some good risers around 3"? What are the specs on the bolts, and how is this done. I know the bars are 7/8" but what I dont know is the measurements on the riser bolts and if I can still use the (IMO nice looking) Triumph logo top clamp, which Id like to. Its very confusing. Some have threaded studs, some dont. Any help, as usual would be greatly appreciated.
Thanks, Jim
RIRAT is offline   Reply With Quote
Old 05-18-2008   #2 (permalink)
jimmyj900's Avatar
The TBS risers should fit-- they work fine on my Adventurer and will give you about an inch rise in front.
Taller risers are a problem. There may be some aftermarket parts for 7/8" bars but you'll have to search for them.
Also, the bolts in the stock risers are JIS rather than DIN so you might not be able to find them long enough, but you can cut down the heads on DIN and make them JIS if you're desperate.
For that much rise you might consider having some spacers made up that are the same base diameter as the stock risers and bolt in from the bottom.
Jim
Old 05-18-2008   #3 (permalink)
Favorite Bike: Legend-01 Emerald Green
Other Motorcycle: Honda NTV 650 Revere
http://www.bike-teile.de/index.php?s...&teilid=430660 and http://www.bike-teile.de/index.php?s...&teilid=430661 I think that the price is 21.95€ each, so you habe to pay 44€ to have them both. All you have to do is ask there or find another breaker nearer you.
Proffa66 is online now   Reply With Quote
Old 05-18-2008   #4 (permalink)
RIRAT's Avatar
Thank You
Thank you very much. That beats the $80US each they are here...but i have to look at shipping.
Jim
Old 06-02-2008   #5 (permalink)
RIRAT's Avatar
ok, one more question
When I ordered them, they asked me if I wanted the top clamp. I said no assuming that the clamp with the triumph logo that came stock on the legend will fit. Is this correct? Thanks again for any help, Jim
Old 07-24-2008   #6 (permalink)
Newbie
Try these for your riser problem?
http://www.triumph-online.co.uk/sw-m...ver-2318-p.asp
Let me know if it helps, I may be able to hook out one or 2 more links for you.
FilthyMcNasty is offline   Reply With Quote
Old 07-24-2008   #7 (permalink)
Favorite Bike: 03 Thunderbird
Other Motorcycle: OIF Bonnie
Jim
Shipping across the pond is pretty costly now.
Beemie is offline   Reply With Quote
Old 07-24-2008   #8 (permalink)
Favorite Bike: 1996 Adventurer
Other Motorcycle: 2000 DRZ400-S
Extra Motorcycle: 1982 KZ 750
I have these on my DRZ:
http://www.rockymountainatv.com/prod...FamilyId=12976
They are not very pretty if you end up stacking up the spacers to get the height you want, but they are cheap and they work well.
gregp is offline   Reply With Quote
Old 07-25-2008   #9 (permalink)
There is a high and a low superbike bar bend out that both raise and bring the bar ends back. My bike had the low bend when I got it (and has individual caps), too low and forward for my stubby armed 5' 10" reach. I did as Jimmy has suggested and ground the heads down on some longer bolts, then bought a box of fender washers. Recovering from a drop was an ideal opportunity to install the high superbike bend bars. Mucho better. Still need a bit more.
Had the wind help me out a few days ago (oy!) and the right bar is almost perfect (bent back and slightly up). I have been planning on a change to HD Deuce risers and a drag bar.
The HD risers are threaded for 1/2" bolts. The Triumph use 8 mm (almost 3/8"). Going to look for bushings, as I already have a 3/8" drill.
Yee-haaaaa!
Gen Mar Handlebar risers vintage96e Trophy 5 05-17-2007 11:49 PM
Handlebar Risers BillyRaff Twins Talk 6 05-20-2006 10:35 PM
handlebar risers hal26 Speed Triple Forum 1 05-06-2006 12:27 PM
handlebar risers Legendman Hinckley Classic Triples 4 09-06-2005 05:15 PM
Handlebar risers on UJMrider Hinckley Classic Triples 2 08-26-2005 12:52 PM
