Being in the same market (new skins) I was reading some of the misc info at the Dunlop site. I quote:
Our inspections have not been limited to those cycles fitted with Dunlop tires; the situation exists for all brands of tires.
Regardless of the make of tire, this is a serious problem. Riders of motorcycles with significantly underinflated and overloaded tires will experience handling and steering difficulty. In addition, this abuse will result in disappointing premature tire wear and may cause catastrophic tire failure.
The addition of accessories, cargo, and dual riding to touring motorcycles aggravates the problems of overloading and underinflation. The excessive flexing that results from underinflation or overload causes buildup of internal heat, fatigue cracking and eventual carcass breakup resulting in complete failure. A consequence of such failure may be an accident with serious personal injury or death.
The appearance of stress cracks in the tread grooves is one indicator of overload and/or underinflation. If you find evidence of tread groove cracking, you should remove and replace the tire immediately. This damage is permanent and non-repairable.
Our inspection of tires of various style and manufacture at rallies and our subsequent testing have confirmed that underinflation (and/or excessive load) causes tread groove cracking and can result in more serious damage within the tire body. Uneven wear may also accompany underinflated use. Failure to heed these visual warnings can result in tire failure or blowout.
That may not have been your issue. I would expect any tire stored in other than poor areas (Dunlop has a list for that too) to easily last more than two years.
Anyhow, I had a set of the old Azarro's. Thinking of either the newer model or the new Dunlop. Am finishing off a set of the Conti Roadattack's. Seem good, no complaints, just wore out the front first (7000 miles; reflects my braking style). I expect that my ride will improve as the front has some scalloping (with this design I wouldn't quite call it cupping -- though it is).
Running a 170/60/17 versus the 160/70, as that is a higher load rating tire (ST1100's and BMWs use this size).
Yee-haaaaa!
