Old 05-15-2008   #1 (permalink)
Newbie
Favorite Bike: 77 T140V- 750 BONNEVILLE
Other Motorcycle: 00 900 THUNDERBIRD
Proven Set Ups-fInal Drive, Engine & Rear Wheel Sprockets
Curious-
Does Anyone Know Of A Sports Model Triumph Or Other Make, Which Has Engine & Rear Wheel Sprockets To Fit A 2000 T Bird???..............
Maybe A Carburettor Model Speed Triple Or Daytona.........?:d
Would Like To Play,
Get Some More Balls Off The Line & Get The Front Wheel In The Air.......
I Know She's Capable, Cruiser Gearing Holds Her Back.
IN TIMES OF PEACE, PREPARE FOR WAR!!
TRUMPYJEFF is offline   Reply With Quote
Old 05-15-2008   #2 (permalink)
Favorite Bike: Speed Triple 1050
welshrob's Avatar
I can wheely mine with the standard gearing, in 1st but it`s not easy. The last time I tried, I yanked so hard on the bars I wrenched my shoulder!!
Getting pattern sprockets to fit should be no problem. Going one down on the front is usually the easiest fix for regular use but if you want to do wheelies, I would strongly advise going up teeth on the back rather than down on the front. As a rule of thumb, 4 up on the back equals 1 down on the front but you also have the option of 3,2 or 1 teeth if you think a milder reduction in gearing would do the trick. You will probably need a longer chain to do this but it is worth it. By wheelying with a smaller front sprocket the extra torque you will be putting through the countershaft will most likely bugger the oil seal or worse still, snap the countershaft.
"Thats Numberwhang!"
welshrob is offline   Reply With Quote
Old 05-15-2008   #3 (permalink)
jimmyj900's Avatar
A smaller front sprocket than stock will probably eat the chain guides on the swingarm.
Jim
Old 05-16-2008   #4 (permalink)
Favorite Bike: 1996 Adventurer
Other Motorcycle: 2000 DRZ400-S
Extra Motorcycle: 1982 KZ 750
Sprockets are available for your bike in several configurations. But most of us here have desired higher final gearing, if anything. Not lower.
gregp is offline   Reply With Quote
Old 05-16-2008   #5 (permalink)
Favorite Bike: 98 Thunderbird
Fogive my pedantry here, but for the sake of accuracy, the ratio is actually about 2.5:1
Old 05-16-2008   #6 (permalink)
welshrob's Avatar
The ratio is dependent on the difference in size between front and rear sprockets that the bike comes with. If it has a larger front sprockets and a smaller rear, so the rule of thumb would be nearer 1 down on the front = 2 up on the back but you`re quite right on a T-bird it`s nearer 2.5 than 4.
I found this great article about changing the gearing on a TBS, which comes with a gearing chart and some 'how to' pics. hope it helps.
http://www.webbikeworld.com/t2/motor...hain-sprocket/
Old 05-17-2008   #7 (permalink)
Administrator
Favorite Bike: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
Just FYI,
There are Gearing calculators for both the 5 speed and 6 speed models in the Blogs.
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is offline   Reply With Quote
Final Drive jfcroni The Rocket Science Forum 4 07-09-2007 12:31 PM
Final Drive Number four! BIKERDICK The Rocket Science Forum 9 12-19-2005 08:14 AM
More thinking out loud: Final drive question, why not Belt drive or Shaft drive? rudebwoy85 Speed Triple Forum 10 11-07-2005 09:13 PM
Final drive ratio Daytona Deliberations 3 03-29-2004 08:52 PM
