Adventurer: what size handlebars, etc? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 03-14-2005, 04:15 PM   #1 (permalink)
I am looking at buying some minor accessories for my '99 Adventurer and was wondering what the sizes are for the following items:
handlebars: 7/8?
rear view mirror mount: 10mm?
Also, can I just put normal aftermarket handgrips on this bike, or does it need to integrate the throttle cable? Doesn't the TBird grip work well?
Thanks!!!
Old 03-15-2005, 07:53 AM   #2 (permalink)
Spider, you have the measures right. Any grip in the 7/8" variety will work for you, but you'll probably have to modify the throttle tubing a bit (ie remove some of the plastic)
I know, 'cause I ordered some standard bonnie grips only to find out they're actually 1". Needless to say, after some scratching of the beard I used a fair amount of duct tape. Works really well.
But you'll be getting proper 7/8" grips of course .
T'Weed
The future's so bright, I gotta wear shades
Tumbleweed is offline   Reply With Quote
Old 03-15-2005, 09:28 AM   #3 (permalink)
Favourite Bike: Adventurer Special
Regiz's Avatar
Other Motorcycle: Honda NX650 Dominator
Extra Motorcycle: Honda VFR 750 '92
Armonic steel spiral, more than palstic...
With 25mm cross handelbar you see on my album (downlinked) all was right with original lenght, (except little gas turning right) but... :razz:
YEAH, I used scissors for steel-sheet to short the pipe when I putted on my Tommaselli YOTA BAR!
(veeeery goooood occasion :-) to grease the wire).
...............- hang on -..............
View Regiz Album
Regiz is offline   Reply With Quote
Which handlebars to get? Reppyboyo Triumph SuperSports 5 09-19-2007 10:55 PM
New Handlebars Nzbiker Twins Technical Talk 3 01-20-2007 07:37 AM
Handlebars Elim Twins Talk 5 01-29-2006 10:49 PM
1999 Adventurer headlight size? SARUNAS Hinckley Classic Triples 11 11-02-2005 10:25 AM
handlebars? Blownfuse Classic, Vintage & Veteran 4 08-19-2005 12:57 PM
