Motorcycle.com
Old 05-13-2008   #1 (permalink)
Favorite Bike: 99 Legend
jwolf's Avatar
Coil/spark plug lead switch- problem or not?
While performing a valve adjustment I noticed the number 3 cylinder (right side as viewed from rear) had a lead from the coil with the number 1 on it.
Bike has been running fine, previous owner replaced bad coil last summer with Nology. Did the leads just get switched, and does it matter? To sum up, the coil closest to the rear of the bike is supplying the #3 cylinder, but has a lead marked #1 on it. Problem or not?
jwolf is offline   Reply With Quote
Old 05-13-2008   #2 (permalink)
jimmyj900's Avatar
As long as the #3 coil connects to the #3 plug, the number on the wire doesn't matter.
Just be sure you don't connect the #3 coil to the #1 plug or you WILL have a problem.
Jim
CAUTION: This post may have been altered and critical safety information deleted without the permission or knowledge of the author.
Old 05-13-2008   #3 (permalink)
jwolf's Avatar
[quote=jimmyj900;1026107]As long as the #3 coil connects to the #3 plug, the number on the wire doesn't matter.
Thanks Jimmy, but still a bit of confusion. Is the coil closest to the rear of the bike the #3? I would assume so, as the bike has been running fine, but can't find any references in Haynes as to numbering of coils.
Old 05-13-2008   #4 (permalink)
jimmyj900's Avatar
The coils run 1-2-3 from front to back and the cylinders run 1-2-3 from left to right.
Makes sense since the plug wires are all the same length.
Jim
Old 05-13-2008   #5 (permalink)
jwolf's Avatar
Thanks guys, that puts an end to the question. I'll just swap out the leads from the coils to the spark plugs.
Wanted- Spark Plug/ Coil Wires Roverdrive Trophy 2 10-03-2007 01:21 PM
New Ignition Coil, Spark Plug Wires and Iridium Spark Plugs...better performance? brownbomber Twins Talk 11 04-03-2007 04:14 PM
Spark plug problem jcline8 Twins Technical Talk 7 03-23-2007 05:33 PM
Accel coil and spark plug wudstoc Classic, Vintage & Veteran 2 01-31-2005 12:47 PM
replacing spark plug lead Modifications & Workshop Talk 0 10-26-2004 01:08 AM
