BikeBandit
Old 05-15-2008   #11 (permalink)
Favorite Bike: jury is still out
Other Motorcycle: 98 Adventurer
Extra Motorcycle: 80 kz650 kawasaki
Mick,
Do you know of any that are an easy changeover? I can never remember to close the ****ed thing, and if iI do I forget to open it. Comes from having a Kawasaki. Thanks
Bbogie is offline   Reply With Quote
Old 05-15-2008   #12 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
Slinky had that info I believe. Also take a look in the parts interchangeability thread in the workshop forum - IIRC somebody posted kawasaki part numbers in there of ones that woudl directly swap on - I think gregp's recommendation above may be one of them.
Mick...
Old 05-15-2008   #13 (permalink)
I had a small leak as well. I removed the petcock and took it apart, real simple. I cleaned the old part, put it back together and it stopped.
I was told you can buy petcock rebuild kits for a couple dollars. Basically a small plastic conic piece and a couple O-rings. But I have not gotten to that point yet.
01Legend is offline   Reply With Quote
Old 05-16-2008   #14 (permalink)
Favorite Bike: 98 Thunderbird
As per Gregp's post, the tap from a ZR70 (Zephyr) is a straight swap- it's the one I used. You can see it on the powersports website- the ref number is 51023-1175.
You may want to use shorter bolts, as the OEM Triumph tap uses a spacer which is not needed on the Kawa tap.
Fuel leak recall question wesalexleft Sprint Forum 17 03-02-2008 09:18 AM
Fuel starvation - Petcock? TLCS3 Twins Technical Talk 1 07-31-2006 08:43 PM
T3 fuel tap/ petcock/ rebuild Mclaren58 T3 Sport / Touring Forum 3 06-28-2006 02:44 AM
Fuel Petcock grumpyoledude Twins Talk 32 12-07-2005 11:14 PM
fuel leak/shutoff question barko1 Tiger Chat 2 10-15-2005 11:35 AM
