Suspension settings - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-09-2008, 02:04 PM   #1 (permalink)
Suspension settings
Hey guys
Just another "stupid" kind of question.
My TBS seems to be set up for the "firm" ride. However in my opinion the front end still "dives" under braking. I am 200 lbs.
Stupid questions
1. On the front spring pre load. By screwing the nut clockwise to allow more lines to be seen actually softens the suspension?? I had to do a double take on this. Screwing clockwise always makes me thing of "firming" things up. Mine is set to show 4 lines. This should be pretty firm??
On all of my adjustments where you count the "clicks" from fully clockwise. When fully screwed in each adjuster will sound the initial click almost straight away as you begin to screw anti clockwise. Is this still counted as a proper click??
Told you they were stupid.
Thanks for any clarification
Tomsdad
tomsdad is offline   Reply With Quote
Old 05-09-2008, 02:16 PM   #2 (permalink)
Administrator
Favourite Bike: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
Check out this link:
http://www.thunderbirdsportriders.ne...Supplement.htm
Scroll down to Section 3
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is offline   Reply With Quote
Old 05-09-2008, 03:09 PM   #3 (permalink)
Thanks, but I had already been there. It just replicates the info in the manual.
Tomsdad
Old 05-09-2008, 06:57 PM   #4 (permalink)
Favourite Bike: TBS 98, only1 i have
du_ratai's Avatar
Other Motorcycle: Motorcycles
I'm about 220-230lbs (maybe more, but not too much).
Dives?
I think it must a little. To absorb smooth Irish roads.
Last front fork service was done by mechanic not familar with TBS, so i have front compresion full on (screw on to the end, not sure about fork oil level it may be bit higher), rebound damping 4, sprig preload 5, rear 4 and 4.
Bike hard. Once i tried bit more, then bike get "wooden".
sorry, i never learned English, even worse! i make errors writing mother language.
du_ratai is offline   Reply With Quote
Old 05-11-2008, 11:28 PM   #5 (permalink)
Favourite Bike: Thunderbird sport
oil-spitn-rat's Avatar
Other Motorcycle: Ducati- PS 1000 LE
Extra Motorcycle: speed trip
Have you tried heavier fork oil in addition to more preload?
Speed is just a question of money how fast do you wanna go?
oil-spitn-rat is offline   Reply With Quote
Old 05-12-2008, 01:03 AM   #6 (permalink)
Favourite Bike: '04 Triumph TBS
cpallen's Avatar
Other Motorcycle: '05 BMW R1200 GS
TBS Suspension Settings
On the front preload, the 27mm nut is the fork cap and should be tight. the 17mm adjuster (with only two flats) is the preload adjuster and as you turn it clockwise, fewer lines should show, and the preload is increased.
The screw in the top is the rebound damping, and the one in the lower fork leg is for compression damping. Clockwise increases the amount of damping and you should always count clicks from full one turning counterclockwise. Under the cap, there is a specific setting for how far the preload adjuster is threaded onto damper rod tube, with a lock nuts to hold it in place.
Here's a couple of good reference articles:
http://www.webbikeworld.com/tbird/fork/ (changing fork oil)
http://www.triumphnet.com/st/acc/racetech/setup.htm (setting suspension sag).
I hope this helps.
Courtney
cpallen is offline   Reply With Quote
Old 05-12-2008, 02:48 PM   #7 (permalink)
Well I told you it was stupid.
You got it right on. I was looking at the big 27mm nut (thats what the arrow in the haynes manual picture seemed to point to), thinking this can't be right.
Adjusted everything now back to factory stock settings. Previous owner had adjusted pre load right down but left everything else alone.
Bike works pretty good now. A good starting point to make small adjustments from.
Thanks for your help.
Tomsdad
Old 05-12-2008, 03:53 PM   #8 (permalink)
Favourite Bike: 1996 Thunderbird "Nessie"
cafetbird's Avatar
Other Motorcycle: 1973 Trump TR7RV "Loosie"
Extra Motorcycle: 1968 BS 350 GTR "Smokie"
FYI - typical factory settings for a bike are set up for a rider that is 160 lbs to 180 lbs. If you are heavier (or lighter) than this, your suspension probably needs adjusting. You should also firm up the rear a bit when you carry a passenger.
Scot Dail, IBA #31553; 59 Club #29906
"Thunderbirds are GOOOOOOOO!"
Old 08-23-2010, 02:26 PM   #9 (permalink)
Other Motorcycle: APRILIA RSV Mille
Good day,
I don’t have the owner’s manual and I’m trying to find some info about factory set up without success.
Can anyone give me factory settings in order to tune mine? I have the same problem, as previous owner did a mess with the settings. Too firm for me.
zappalia is offline   Reply With Quote
suspension settings ricster Sprint Forum 4 07-01-2007 08:01 AM
suspension settings. mongo Speed Triple Forum 1 02-23-2007 07:21 AM
Suspension Settings daveyw Tiger Workshop (archive) 1 08-19-2005 12:01 PM
Suspension settings? What do you use. PowerhouseS3 Speed Triple Forum 7 08-08-2005 06:42 AM
Suspension Settings yellowTBS Hinckley Classic Triples 1 05-30-2004 03:00 PM
