Motorcycle.com
Old 05-09-2008   #1 (permalink)
Suspension settings
Hey guys
Just another "stupid" kind of question.
My TBS seems to be set up for the "firm" ride. However in my opinion the front end still "dives" under braking. I am 200 lbs.
Stupid questions
1. On the front spring pre load. By screwing the nut clockwise to allow more lines to be seen actually softens the suspension?? I had to do a double take on this. Screwing clockwise always makes me thing of "firming" things up. Mine is set to show 4 lines. This should be pretty firm??
On all of my adjustments where you count the "clicks" from fully clockwise. When fully screwed in each adjuster will sound the initial click almost straight away as you begin to screw anti clockwise. Is this still counted as a proper click??
Told you they were stupid.
Thanks for any clarification
Tomsdad
tomsdad is offline   Reply With Quote
Old 05-09-2008   #2 (permalink)
Favorite Bike: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
Check out this link:
http://www.thunderbirdsportriders.ne...Supplement.htm
Scroll down to Section 3
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is online now   Reply With Quote
Old 05-09-2008   #3 (permalink)
Thanks, but I had already been there. It just replicates the info in the manual.
Tomsdad
Old 05-09-2008   #4 (permalink)
Favorite Bike: TBS 98, only1 i have
du_ratai's Avatar
Other Motorcycle: Motorcycles
I'm about 220-230lbs (maybe more, but not too much).
Dives?
I think it must a little. To absorb smooth Irish roads.
Last front fork service was done by mechanic not familar with TBS, so i have front compresion full on (screw on to the end, not sure about fork oil level it may be bit higher), rebound damping 4, sprig preload 5, rear 4 and 4.
Bike hard. Once i tried bit more, then bike get "wooden".
sorry, i never learned English, even worse! i make errors writing mother language.
du_ratai is offline   Reply With Quote
Old 05-11-2008   #5 (permalink)
Favorite Bike: Thunderbird sport
Other Motorcycle: Ducati- PS 1000 LE
Extra Motorcycle: speed trip
Have you tried heavier fork oil in addition to more preload?
I think your radar must be off...
oil-spitn-rat is offline   Reply With Quote
Old 05-12-2008   #6 (permalink)
Favorite Bike: '04 Triumph TBS
cpallen's Avatar
Other Motorcycle: '05 BMW R1200 GS
TBS Suspension Settings
On the front preload, the 27mm nut is the fork cap and should be tight. the 17mm adjuster (with only two flats) is the preload adjuster and as you turn it clockwise, fewer lines should show, and the preload is increased.
The screw in the top is the rebound damping, and the one in the lower fork leg is for compression damping. Clockwise increases the amount of damping and you should always count clicks from full one turning counterclockwise. Under the cap, there is a specific setting for how far the preload adjuster is threaded onto damper rod tube, with a lock nuts to hold it in place.
Here's a couple of good reference articles:
http://www.webbikeworld.com/tbird/fork/ (changing fork oil)
http://www.triumphnet.com/st/acc/racetech/setup.htm (setting suspension sag).
I hope this helps.
Courtney
cpallen is offline   Reply With Quote
Old 05-12-2008   #7 (permalink)
Well I told you it was stupid.
You got it right on. I was looking at the big 27mm nut (thats what the arrow in the haynes manual picture seemed to point to), thinking this can't be right.
Adjusted everything now back to factory stock settings. Previous owner had adjusted pre load right down but left everything else alone.
Bike works pretty good now. A good starting point to make small adjustments from.
Thanks for your help.
Tomsdad
Old 05-12-2008   #8 (permalink)
Cafe Racin' Moderator
Favorite Bike: 1996 Triumph Thunderbird
cafetbird's Avatar
Other Motorcycle: 2002 Triumph Sprint ST
Extra Motorcycle: 1973 Triumph TR7RV
FYI - typical factory settings for a bike are set up for a rider that is 160 lbs to 180 lbs. If you are heavier (or lighter) than this, your suspension probably needs adjusting. You should also firm up the rear a bit when you carry a passenger.
Scot Dail, IBA #31553
Pack Member, Charlotte RAT
suspension settings ricster Sprint Forum 4 07-01-2007 07:01 AM
suspension settings. mongo Speed Triple Forum 1 02-23-2007 06:21 AM
Suspension Settings daveyw Tiger Workshop 1 08-19-2005 11:01 AM
Suspension settings? What do you use. PowerhouseS3 Speed Triple Forum 7 08-08-2005 05:42 AM
Suspension Settings yellowTBS Hinckley Classic Triples 1 05-30-2004 02:00 PM
