Newbie aux air chamber question - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 03-12-2005, 01:20 PM   #1 (permalink)
johnnysavage
Hi all, recently bought my first Triumph (used 96 Tbird). I'm scratching at the garage door waiting for the weather to warm up so I can start enjoying my new ride.
When I removed the airbox cover I noticed the previous owner had removed the aux air chamber. My searching on this site tells me it's the first part of the two chamber air flow system. How critical is the aux air chamber? Anyone remove it permanently and ride w/o? Does installation of the K/N system require removal of it? My bike has a few aftermarket mods so I'm wondering that has something to do with it???
Old 03-12-2005, 01:40 PM   #2 (permalink)
I am thinking that you wouldn't need the second chamber if you have K&N air cleaners. But, I can tell you right now, I am changing out my air box as we speak, and I am so frustrated that I could kill small furry animals right now. lol
cable1 is offline   Reply With Quote
Old 03-12-2005, 03:27 PM   #3 (permalink)
Slinky's Avatar
It should be there, even with a K&N filter element installed. I imagine that it neing removed will have a detrimental effect.
The other problem I can see is that the seat lock bolts to the aux. air chamber, and if the lock is missing, what is holding the seat on :???:
Slinky is online now   Reply With Quote
Old 03-12-2005, 04:05 PM   #4 (permalink)
Ok, my bad. Sorry bout that.
Old 03-12-2005, 05:18 PM   #5 (permalink)
johnnysavage
Actually, it doesn't have a K&N I was just thinking perhaps the previous owner had installed a system but removed it prior to selling. The seat lock is fixed to the upper portion of the aux chamber. Hopefully that doesn't go airborne at 65 mph :-D
Old 03-12-2005, 07:07 PM   #6 (permalink)
Favourite Bike: 1995 Thunderbird
SWare's Avatar
Airflow would be negatively affected and you will probably hear more intake noise. I hate to think what Triumph wants for one but it wouldn't hurt to check. After that try finding one used. Several people on this board have modified their intake system and may have one available. You could also try some one like Baxter Cycle.
stan
SWare is offline   Reply With Quote
Old 03-12-2005, 10:21 PM   #7 (permalink)
jimmyj900's Avatar
The air box under the seat (not the filter box on the carbs) performs two functions: initial air filtration and noise suppression.
It creates a low-velocity area where particulates in the air stream (grit, water) can drop to the bottom of the box and unless you're in an area prone to dust/sand storms, it's not necessary.
Here in Minneapolis it's only useful as a nesting space for small rodents.
Installation of a K&N filter doesn't require removal of the air box since the single-inlet Classics air filter box provides more than enough restriction to limit engine performance.
Jim
Old 03-13-2005, 05:53 PM   #8 (permalink)
Favourite Bike: R1100S
Shaunlee's Avatar
Other Motorcycle: '02 SV650s
If your bike is from California this box will contain the emission control filters. These bikes have a slighly different vacum line routing also. When I removed my EC filter, the name on the side of the filter was honda. I read somewhere on this sight someone converted this box to a tool box not a bad idea. :-D
Shaun
Shaunlee is offline   Reply With Quote
Old 03-13-2005, 07:21 PM   #9 (permalink)
Gee, I wonder if you could insulate it somehow and use it as a mini cooler? Just a thought. :razz:
Old 03-13-2005, 07:26 PM   #10 (permalink)
Favourite Bike: Triumph
johnyC's Avatar
It was me.
I have a small mesh over the hole for exclusion of field mice on the main airbox intake. The auxiliary box now cotains a tin of 'flat mate', a few cylinders of CO2, a sidestand support in the shape of the Isle of Man and a cloth to supress the rattling.
It made absolutely no detectable change in performance, the only difference was when I tried to get clever and drilled a similar size hole on the other side of the airbox. It then ran like a dog, big hole in the midrange which I fixed with duct tape. If you go the whole road with speed triple cams, etc you could do with an extra hole but the standard bike prefers just the one. :-D
johny. the boy's happy, leave him alone.
johnyC is offline   Reply With Quote
Air "Pods" falling off... Air Box Removal Question boboso Twins Technical Talk 7 08-08-2011 07:55 PM
Newbie question about freeing up air Bucknut Twins Technical Talk 11 01-31-2007 10:42 AM
Newbie question about air injection PeteIllingworth Twins Technical Talk 3 11-21-2006 04:50 PM
Air chamber dripping gas Trophy 7 10-28-2004 04:46 AM
Air chamber dripping gas Maintenance & Workshop Talk 2 10-20-2004 06:16 PM
