Not another oil thread - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!Honda PowersportsNew BonnevilleOntario Tourism
Old 05-08-2008, 03:59 PM   #1 (permalink)
Favourite Bike: 07 Speedmaster
mstrmac's Avatar
Other Motorcycle: 95 Thunderbird
I read all the oil posts and then some. So this is not a oil thread but a specific question regarding when the sight glass oil level should be about half.
After you get 4 litres out and 4 litres in or 4.2267528 Qts. in your TB:
1) Should the level be half?
2) Should the level be half in the sight glass after you start the engine for a few minutes then stop and view?
Thanks
mstrmac
mstrmac is offline   Reply With Quote
Old 05-08-2008, 05:10 PM   #2 (permalink)
Favourite Bike: 1996 Adventurer
Other Motorcycle: 2000 DRZ400-S
Extra Motorcycle: '99 Ninja 250,'04 KDX200
The correct oil change quantity is closer to 3.5 liters. 4 will cover the sight glass totally and may give you some over-fill issues.
gregp is offline   Reply With Quote
Old 05-08-2008, 06:40 PM   #3 (permalink)
mstrmac's Avatar
Thanks i will be careful. Are you saying after engine shut off the sight glass is half or are you saying with a cold engine the sight glass is half?
Old 05-08-2008, 07:21 PM   #4 (permalink)
13
Favourite Bike: BRITTEN
13's Avatar
Other Motorcycle: 955i
I keep mine just under "high" level mark...
I just did my S3 for the million'th time 2 days ago: I fill the filter SLOWLY (if the filter is upright on a TB suggest doing this too); install filter; double check mentally at least that drain-plug is tight (without stripping); fill oil with bike level (wood block under kickstand almost levels bike, careful not to knock bike over); fill oil to about 3/4 into sight glass; replace oil fill-plug; start engine for minute or so to work oil through oil passages...
This usually puts oil at about half way mark in glass. Sometimes I'll go for a short ride, or, let it sit for a few hours or overnight... to answer question, then I top off to "under" high level mark in sight glass. After another short ride check level isn't too high (if it is, you can drain a little out through the drain plug). This sounds like alot but once you're doing it isn't much. I can never seem to drain ALL the oil out, so am content that it takes a little less than spec'd to fill, but am extra cautious not to overfill. Hope this helps!
Btw, on mine, with a cold engine, it's just under the high mark...
SPEED SAVESİ
13 is offline   Reply With Quote
Old 05-09-2008, 08:00 AM   #5 (permalink)
The Thunderbird series does not have a screw on type filter. They just have a pleated paper cartridge element.
Old 05-09-2008, 08:02 AM   #6 (permalink)
I believe that with the engine cold and sitting for a while the level should be 1/2 to 3/4 of the way up the sight glass with the bike straight up and down.
Old 05-09-2008, 08:36 AM   #7 (permalink)
Favourite Bike: 1970 BSA A65 Lightning
Monty's Avatar
Other Motorcycle: 98 Thunderbird
Extra Motorcycle: 79 Bonneville Special
I put my TB on its mainstand(on level ground) and fill it until there's a small bubble at the top of the sight glass, run for a couple of minutes and check if it needs a top up, i just make sure i can see a small bubble in sight glass.
Just remember Gramps!, motorcycles are meant to remind you of your youth, when you last remember being happy, so at least try to relive some of that memory.
Monty is offline   Reply With Quote
Old 05-09-2008, 11:49 AM   #8 (permalink)
Favourite Bike: 2K T-Bird
Other Motorcycle: '98 900 Trident
Extra Motorcycle: '85 Nighthawk
are you an optimist?
I've often wondered: is the sight glass half empty or half full?
"If the women don't find you handsome, they should at least find you handy."
DaleE is offline   Reply With Quote
Old 05-09-2008, 12:07 PM   #9 (permalink)
Is the "Mainstand" you refer to the kick stand (side stand) or the Center Stand? I presume that you are refering to a center stand, which most of us do not have as they did not come stock on these bikes. Hence the request for an accurate fill quantity.
Old 05-10-2008, 07:13 AM   #10 (permalink)
Favourite Bike: 2003 Speed Triple
Other Motorcycle: 1999 Legend
Oil Level
The Haynes Manual (and possibly the Triumph manual) have some mis-prints.
The correct oil amount is 3.75 liters.
Which is just about 1 US gallon (3.79 liters)
4 Liters will over-fill and your bike will weep/leak .
No quarter asked, none given
Gdsila is offline   Reply With Quote
NOT an oil thread! smartin108 Twins Technical Talk 14 09-09-2007 12:03 PM
Thread of the day BorgCymru Twins Talk 5 08-08-2007 12:03 AM
I just wanted to start a new thread so that Benzos thread doesn't keep getting pushed to the top of graciejohn2 Speed Triple Forum 2 11-29-2006 02:47 PM
Thread mercator Sprint Forum 1 07-06-2005 11:07 AM
NOT another Oil thread... sangsters Maintenance & Workshop Talk 2 06-23-2004 01:38 PM
