Ignition/Battery? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-06-2008, 02:47 PM   #1 (permalink)
Favourite Bike: '02 T'Bird 900
TonyD's Avatar
Ignition/Battery?
I know that battery/ignition problems have made appearances here many times, and I have read all the threads I could find, but I've not hit on a solution.
I replaced the battery on my T'Bird after the original failed and left me stranded last autumn. The replacement, an 'MF Super' sealed maintenance free, worked fine thereafter, but I have had the bike laid up since November. I removed the battery at that time and in the intervening months put it on a bike specific trickle charger about once a month.
Put the battery back in today and turned the ignition. No 'click', no idiot lights, no horn etc. Tested with a multimeter - 13.75v no load, dropping to 3.5v once I turned the ignition key (hadn't pressed starter button). Took it off and hooked it up to a bigger charger with a built-in charge indicator - tells me the battery is fully charged (its an 11 amp charger so I don't use it to actually charge the bike battery).
Put it back on the bike, turned ignition key, got weak neutral and oil lights, pressed starter, nothing. Tested again with multimeter, same story as above - full voltage showing until turn of key (but this time, as first time, no idiot lights).
The terminals on the bike battery cables are pristine, so the connections should be fine. I have checked the connections from the ignition switch and also the fuses - they look fine, too. I put the battery back on the trickle charger, but notice that I can hear it gently gurgling away within a few minutes (which I have always taken to be a sure sign that a battery is or is getting close to fully charged).
So what do you think - is the battery duff, is it possible that it is undercharged notwithstanding the reading off my main charger, or is it likely the problem lies elsewhere?
TonyD is offline   Reply With Quote
Old 05-06-2008, 04:09 PM   #2 (permalink)
Favourite Bike: '98 Thunderbird Sport
denny's Avatar
Other Motorcycle: '06 Husqvarna TE 610
Extra Motorcycle: '95 TBird - Project
Sounds like the Battery to me. Do you have a way to get it load tested?
Cheers,Denny
denny is online now   Reply With Quote
Old 05-06-2008, 06:04 PM   #3 (permalink)
Administrator
Favourite Bike: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
<snip.
Tony,
Sounds to me that the battery is just flat.
How long did you leave the battery on the trickle charger?
Using the charge indicator on your charger is not telling you that the battery is fully charged...just that it has a surface charge on the plates.
Hook EITHER charger up and leave it on for at least 12 hours and then try to start it again.
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is offline   Reply With Quote
Old 05-06-2008, 09:34 PM   #4 (permalink)
Favourite Bike: '04 Triumph TBS
cpallen's Avatar
Other Motorcycle: '05 BMW R1200 GS
Originally Posted by Wombat View Post
[snipped]Hook EITHER charger up and leave it on for at least 12 hours and then try to start it again.
DO NOT charge your motor cycle battery with anything with more than a 2A supply!
Courtney
cpallen is offline   Reply With Quote
Old 05-06-2008, 09:54 PM   #5 (permalink)
jimmyj900's Avatar
A battery with diminished capacity can show up as fully charged but have no useful reserve capacity which seems to be the symptom you're describing with the battery voltage dropping to nothing when a load is applied. It simply can no longer supply sufficent power to maintain the voltage.
Was this a gel or AGM battery? I've been kind of curious about the life expectancy of these.
Also, get yourself a 'smart' battery charger with a 2-amp charge limit setting. You should only charge a battery at a maximum 10% of the amp-hour capacity but an occasional 2-amp charge won't hurt them.
Trickle chargers are fine for maintaining a battery once charged but most aren't designed to charge a battery that's seriously depleted.
Jim
Old 05-06-2008, 10:25 PM   #6 (permalink)
Favourite Bike: 2000 Adventurer
Woody1911a1's Avatar
Other Motorcycle: 67 T100C
Extra Motorcycle: Buell Blast
Jim
i'd be curiouse too . my experiences with agm , which is completely different than gel , has been nothing short of stupendous .
beginning of last year i put one in my wife's buell , she rode it maybe 3 times i rode it once . after sitting for 2 months i needed to put it away in december because a storm was coming . it was below freezing and i cranked it for waaaaaaaay to long before it finally started , but the battery just kept going and going !
took the battery out and put it in the garage . no charging nothing ! then last week after a post questioning the agm's i said f*** it . and instead of putting it on the charger first , i just put it back in the bike and .......................... again took a few but the battery just kept cranking away til it started .
hell yea , AGM's rule as far as i'm concerned . put one in my adventurer this january and killed it once by leaving the ignition on .5 days dead . put it on the tender . next day vrooooooom .
agm technology was developed 20 years ago for the military . the only downside is they don't like high temps , but i haven't been able to find what high temps they mean .
gell's are very critical to charging rates and normally require special regulation .
just my 2 cents worth from experience and research . google em . ;_)
ohhh and what i read time and time again in researching was that they self-discharge less than any of the other batteries . good thing for a motorcycle . :-)
Woody1911a1 is offline   Reply With Quote
Old 05-07-2008, 03:04 PM   #7 (permalink)
TonyD's Avatar
Thanks all.
Thanks for the input, guys. Much appreciated.
Definitely the battery (which is simply described as a sealed lead acid battery - think that means its an agm rather than a gel type, but there's nothing on the case to indicate either way). I had a guy who works with my wife bring his T'Bird round to our place earlier and we swapped batteries - my bike fired up first time on his, while we couldn't get his bike started with mine.
I had been trickle charging it once a month for 8 hours or so - but I had it on trickle charge for 12 hours last night and it appears to have made little difference. Maybe, as Jim said in his post, the battery is so depleted the trickle charger can't get it back up to strength. I don't want to risk the 11amp charger for the reason cpallen (and others in previous threads) gave. Or maybe its just a dud.
Anyway, back to the dealer with it!
Old 05-07-2008, 04:27 PM   #8 (permalink)
Favourite Bike: Own a 95 Super111
threepot's Avatar
Other Motorcycle: Luv a R3 !
Extra Motorcycle: None
A tip for ya all....... When using a trickle charger,when it shows green(charged) switch it off then back on. This puts it back in charge mode(does on an Optimate anyway) Do it several times. I was ready to bin a Yuasa till I tried this. Worth a try eh?
threepot is offline   Reply With Quote
dead battery and gas ignition jimmyc Twins Talk 9 01-28-2008 06:14 PM
battery tender OR battery tender junior? dml955i Speed Triple Forum 4 11-03-2006 09:12 PM
ignition fisher0829 Classic, Vintage & Veteran 3 08-14-2006 06:50 AM
remove ignition barrel from ignition switch? kanoa Classic, Vintage & Veteran 3 07-13-2006 01:50 PM
Help me .. Ignition spy is always ON Maintenance & Workshop Talk 5 01-29-2004 10:04 AM
