Engine won't go over 5,000 RPM's..HELP !! - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsSportbikeTrackGear
Old 05-04-2008, 09:41 PM   #1 (permalink)
Favourite Bike: Thunderbird
I put shorty pipes on my T-bird, rode about 40 miles with them between last night and this afternoon.
I took them off tonight at about 7:30pm and put my peashooters back on. Out of nowhere my t-bird wouldn't go over 5,000 RPM's, I'd get to 5,000 and my engine starts sputtering. As I said I charged them back to stock mufflers and it still sputters at around 4,500 RPM's and won't go over 5,000 RPM's, even with the trottle held wide open.
Can anyone answer this question for me? What's the problem? Ron.
RONNS is offline   Reply With Quote
Old 05-05-2008, 01:29 PM   #2 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
loosen the filler cap and see if it still does it then - if it doesn't you have a blocked tank breather or hose. Otherwise its very likely you have one of the following :
Blocked fuel filters (petcock or carb tee)
Float height incorrect (bad adjustment, or contamination of float / valve)
Bad mixture - have you changed the jets? If not they may just be partially blocked.
There could be other reasons too but this would be a good start
HTH
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 05-05-2008, 03:39 PM   #3 (permalink)
Favourite Bike: 1995 Speed triple
I also had a similar problem with my S3, after wasting some money on ignition coils and wires i decided to go through the carbs once more and I found the main jet in #3 cylinder was in the bottom of the bowl. This happened very suddeenly too. The engine got to 4800 very nicely and it was just like it hit a rev limiter hard
If at first you don't succeed, hit it with a bigger hammer
Lushy is offline   Reply With Quote
Old 05-05-2008, 08:48 PM   #4 (permalink)
jimmyj900's Avatar
Possibles in no particular order of probablilty:
Dropped main jet (like Lushy says), damaged diaphragm, jammed carb needle, stuck carb slide, broken slide spring, bent/jammed slide spring.
You're going to have to pull the carbs and check them out.
Jim
Old 05-05-2008, 09:57 PM   #5 (permalink)
Favourite Bike: '01 Legend TT
ShikePoke's Avatar
Other Motorcycle: I can have two?
I agree with previous two. I had the same issue. Main jet fell in bowl. Bet my sisters dog on it.
Poke
ShikePoke - "Hated to kill the boy...but he needed to be taught a lesson..."
ShikePoke is offline   Reply With Quote
'67 TR6 RPM's pochie Classic, Vintage & Veteran 6 01-14-2008 10:49 PM
RPM's @ 80 unitedrocker Twins Technical Talk 5 07-30-2007 01:30 PM
99 Sprint ST, Engine Cutting off at lower RPM's. BigAssRat Sprint Forum 5 08-02-2006 04:50 PM
RPM's KarmaPunk1 Speed Triple Forum 5 06-01-2006 09:01 PM
RPM's Whisperinsmith Twins Talk 8 06-29-2005 09:13 AM
