Throttle Cable - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 05-04-2008, 05:55 PM   #1 (permalink)
Throttle Cable
Just replaced the throttle cable on my 99 TBS. Was time consuming but not as difficult as I anticipated. It took me a few hours on a sunny sunday morn. Sliding the carbs back and removing the front 2 coils provided enough clearance. Was able to install the new cable to the carbs with a flat screwdriver and a pair of needle nose pliers.The job is within the scope of the average rider,.......Saved quite a bit by not taking it to the dealer. The question is...why did it fail after only 16k on a garage queen?
swamper650 is offline   Reply With Quote
Old 05-04-2008, 06:24 PM   #2 (permalink)
Favourite Bike: 99 Triumph Adventurer
meths389's Avatar
Other Motorcycle: Not enough cash or time!
Mine snapped after only 13k, in two places, which made no sense when I took it apart. From what I saw when I removed the old cable I found a lot of corrosion despite my bike being garaged too. How the previous owner stored her I couldn't say as I bought my bike from a dealer.
Without being cynical, maybe it's just another example of quality British engineering?
meths389 is offline   Reply With Quote
Old 05-04-2008, 06:29 PM   #3 (permalink)
Favourite Bike: 2000 Adventurer
Woody1911a1's Avatar
Other Motorcycle: 67 T100C
Extra Motorcycle: Buell Blast
"why did it fail after only 16k on a garage queen?"
you lube it regularly right ? i can't understand it either
Woody1911a1 is offline   Reply With Quote
Old 05-04-2008, 08:04 PM   #4 (permalink)
Favourite Bike: Me Thunderbird of course
Other Motorcycle: Toyota Landcruiser
Extra Motorcycle: IT 490
They fail because they are crap quality cables. I replaced mine with a decent cable at 22,000klms, and have done another 100,000 since on the same cable. Find a good cable maker, don't buy those dodgy Triumph genuine parts.
I believe there is no such thing as accidents. When I ride I must leave enough room for others stupid mistakes, added to that is enough room to make my own.
WoodsieIII is offline   Reply With Quote
Old 05-04-2008, 08:56 PM   #5 (permalink)
it is a crappy cable and with the end on the outer casing you can't use a cable luber so i use a good teflon lube and give it a few good squirts everytime i take the carbs out . (once every month or so lol ) .
you got any better suppliers ?
Old 05-05-2008, 04:32 AM   #6 (permalink)
Dont have any suppliers as such, I take mine to a bloke who makes cables in Brisbane. He does a lot of marine cables, and just makes the new one using the old as a sample. About half the price of triumph too. I went through a stage where I was getting through speedo cable regularly, found the all broke in the same place, down near the wheel. I put some spiralguard around it, and haven't broken one since. I figure it was getting hit by rocks. ( I regularly travel a road which has 40 klms of pea gravel)
Old 05-05-2008, 07:18 AM   #7 (permalink)
Administrator
Legend
Favourite Bike: '98 Triumph Thunderbird
Tbirdnz's Avatar
Other Motorcycle: '05 Honda CB1300
I replaced my throttle cable on my '98 TB at 65,000km prior to going on a 3 week tour. It hadn't failed and when I checked it out it was still perfect. It pays to run a bit of light oil down them although I had only done that at 30,000km.
Ride on !
Tbirdnz is offline   Reply With Quote
Old 05-10-2008, 11:31 AM   #8 (permalink)
Favourite Bike: 77 T140V- 750 BONNEVILLE
Other Motorcycle: 00 900 THUNDERBIRD
Throttle Cable
2000 t bird, 30,000kms....had cable snap halfway, looked to be original. I go to a place in Milperra N.S.W, Australia......bought 5 metres of inner cable & 6 nipples for $5.00 Australian.
Copied original, first effort was a bit short after i soldered it up....so went a fraction longer & sucess!! I figure that theres nothing wrong with the outer cable, so why change it unless horribly kinked???
Do the same with clutch cables on my womans hinckley bonnie & my meriden bonnie, but with thicker inner cable of course than a inner throttle cable.....
TRUMPYJEFF is offline   Reply With Quote
Old 05-10-2008, 09:52 PM   #9 (permalink)
Favourite Bike: The one I'm on
Other Motorcycle: 2006 Sprint ST ABS
Extra Motorcycle: 2000 Thunderbird
I guess I'm the"one in every crowd"
For my 48,000 mile service on my 2000 T'bird, I said "better put a throttle cable on it, too"
They did it when they had the carbs off and gave me back the original. I still have it as a spare - there was nothing wrong with it!
Could you see me if I was standing on your hood kicking in your windshield?
upNorth is offline   Reply With Quote
Throttle cable help Malibu Twins Technical Talk 3 04-12-2008 02:48 PM
throttle cable ricster Sprint Forum 1 05-01-2007 10:26 AM
Throttle cable H Tiger Workshop (archive) 2 04-19-2007 04:51 PM
Throttle Cable lord_nibbler Sprint Forum 9 02-26-2006 08:29 AM
Throttle cable ??? 99 vs 02, 1x or 2x cable? robadele Sprint Forum 8 01-07-2005 08:25 PM
