Maintenance is straight forward. Only one special tool (~$50) needed (well, preferred, not really needed) and that is for the valve adjustment. All very standard technology any motorcycle mechanic (non-HD) can do. And, if you are used to adjusting your own valves, then nothing you can't do (standard Jap bike shims).
Jap parts: carbs, charging system, switches (?), brakes, levers, shocks, forks, gauges.
Italian: seat (bummer, not leather).
Ignition: German and/or British (work the same).
Thailand: wiring harness (2003 TBS).
A triple is like nothing else (and save an old Yamaha or Benelli, about the only one to ride). You might want to check out a Speed Triple or new Tiger.
Yee-haaaaa!
