Originally Posted by kyre_kyre
#1 = 12.11 V
#2 = 0.75 V
#3 = 0.003 V
#4 = 11.34 V
#5 = 12.10 V
The first and last tests checked the condition of the battery with the headlight and ignition system as a load. That looks good, so your battery is OK.
The second test checked the condition of the wiring and switches from the battery to the igniter module and that's looking very good. (Better than my bike!)
The third test verified the quality of the system ground and that looks fine too.
The fourth test verifies the results of the second and third tests and eliminates errors of meter accuracy. Add #2, #3 and #4 and that should total the battery voltage. You're only 0.02 volts off so that's well within the limits of accuracy of your meter.
The symptom you gave -- that the engine shut off at an idle like a switch flipped rather than slowing down and quitting -- and also that nobody could find the problem led me to suspect that the series resistance from the battery to the igniter and from the igniter to ground was high enough that it was switching the igniter off.
The Gill ignition appears to shut down someplace between 5 and 8 volts AND there's about 12 feet of wire with over 40 electrical connections between the battery and igniter. That wire length and all those connections made that a prime candidate for high resistance. It's also a problem that your average bike shop would probably never find.
The good news is that there's not enough of a voltage drop through the system to cause an igniter shutdown. Your voltage drop is about 1/2 the drop on my bike and I'm not having a stalling problem, so you don't have to take the wiring harness, switches and connectors apart.
It was a bit of a long shot but had the benefit of verifying the condition of the electrical system.
The next step is to go to basics and test the coils.
Make sure your battery is fully charged first, then hang a spare spark plug from each of the ignition wires (one at a time) and apply a good ground to the big end of the spark plug. (I use a car jumper/booster cable to the base of the footpeg.)
Crank the engine and look at the spark. If it's thin and yellow then it's a weak spark. If it's fat and blue it's a good spark.
It's common on these engines to have one coil fail and go weak. Two coils bad usually means the idle gets rough enough that either somebody replaces the coils or hauls it off to the shop for repair. Three coils bad at once happens occasionally too.
The problem is that these coils rarely fail completely with no spark.. They go weak but still fire adequately at higher rps where the alternator supplies power. The lower battery voltage at an idle makes the weak coils visible.
So the battery looks good, the wiring is in good shape and a coil test comes next.
Jim
