So I've been pulling my TBird around again... No big surprise there (I think it keeps me sane through the winter).
Usually I try to use pretty much all Triumph stuff where I can. However, the mods this year are a departure from the norm.
I wanted to upgrade the front brakes but also wanted to go to 17" wheels. The obvious route was to use TBS parts but these are rarer than rocking horse poop. The one set of forks etc. that I did find on ebay (after looking for 3 years) I was outbid/outsniped on by a long margin.
So I started looking for other sources of parts. I hit upon the idea of using Kawasaki ZRX1200R parts largely because the fork diameter is the same as that of the TBird.
Current status is that I have a ZRX front end mounted up - the rear wheel is working out, although I do need to do some shimming / make spacers (anybody have a lathe and could turn down a spacer for me?).
Rear brake will come from a pre-1996 Trophy as the ZRX rotor is almost the same size as the Trophy item at 250mm (Trophy is 255) as opposed to the TBird's 285mm item. the Trophy parts look like they will just bolt right up. The back wheel goes from a 150/80-16 tire to a 180/55-17 the front goes down to a 120/70-17. The front brakes are the Tokico 6 pots from the ZRX.
Currently I am liking the look of the darker front end - I painted the headlamp brakets in satin black to match the forks. Let me know what you think?
You can see progress so far
Here
P.S. You may also notice the swap back from last years clip-ons to the 2003 bars. In the end I just preferred the way it felt to ride it with the bars.
[ This message was edited by: MickMaguire on 2005-03-09 10:41 ]
