Old 04-27-2008   #1 (permalink)
Buelly's Avatar
Other Motorcycle: 2000 Buell S3T
Fuel filter?
Put my gaiters on yesterday. Look awesome. Decided to go exploring under the gas tank. Noticed the fuel line from tank to carbs has no fuel filter. Is this normal? Also, I have never seen a bike with an air filter that is so difficult to replace. Do carbs have to be moved to replace air filter? Routine maintenance looks like it will be a little challenging.
1999 Legend...the black beauty...well metallic silver/black beauty
Buelly is offline   Reply With Quote
Old 04-27-2008   #2 (permalink)
jimmyj900's Avatar
There's a mesh filter in the fuel tank and a duckbill filter in the T where the fuel line connects into the carbs.
I've added a small filter into the fuel line that I use as an indicator more than anything else -- if there's junk in it, I'm in trouble!
There's a pic in my album under 'Carbs, Intake and Fuel System' so use the clicky below to take a look.
Yep. It's a PITA and you do have to remove the carbs to get the filter out.
Remove the tank, remove the side covers, remove the left side airbox, remove the plastic trim strip that's attached to the coils, loosen the clamps on both sides of the carbs, pull the carbs and filter box back as an assembly, push the carbs off the filter box, slide the carbs out the left side, push the filter box forward and remove it.
Simple, huh?
It's pretty straightforward after you've done it a couple of times and gotten the hose clamp screws unstuck.
Jim
Old 04-27-2008   #3 (permalink)
Favorite Bike: 2000 Adventurer
Woody1911a1's Avatar
Other Motorcycle: 67 T100C
Extra Motorcycle: Buell Blast ;-)
also when pulling the carbs it's way easier to undo the throttle cable at the throttle end rather than the carb end .
sounds like a pita , but after you've done it once you can get them off in less than one beer ;-)
good chance to clean out the float bowls and jets . maybe even check the float heights .jimmyj900 did a great write up on float height here http://www.triumphrat.net/hinckley-c...at-height.html
Woody1911a1 is online now   Reply With Quote
Old 04-27-2008   #4 (permalink)
Buelly's Avatar
Thanks guys. I'm definitely going to add a small gas filter.
How much for a new fuel filter? bundo Speed Triple Forum 8 01-21-2008 02:51 AM
Fuel Filter? ukilme Triumph SuperSports 2 09-26-2006 10:11 AM
fuel in the air filter!!! wrack Modifications & Workshop Talk 6 06-03-2006 03:06 AM
Fuel Filter/oil filter/oil type Anchorbend Twins Talk 4 07-24-2005 01:00 AM
Fuel Filter Sprint Forum 4 05-11-2004 07:11 AM
