Have no fear.
Was a piece of cake. Took about 1.25 - 1.5 hours. 96 Adventurer. Old clutch side bolt was polished flat from the aux drive gear
Things to consider before starting:
You will need:
New alternator drive cushions
New driveshaft kit
Clutch cover gasket
Alternator to engine case o-ring.
8, 10, 13, and T-30 sockets/drivers
A good manual that explians the alternator & clutch removal process
A 1/2" drive air impact or the special clutch basket removal tool(holds the baskets still but not needed if you have an impact)
A 30mm socket for the above clutch nut
I will post a reply with the Triumph P/N's later from home.
Push the new shaft thru from the clutch side and make sure the splines are lined up. Mine took a few good hits with a dead blow hammer.
The hardest part is aligning the aux drive gear back up with the main gear and pushing in the splined centering insert. Have a lot of patience there. Get up and take a walk a few times. You will get it after a few tries.
Good luck and sorry I didn't take any pictures.
You will need:
New driveshaft kit
Clutch cover gasket
