Old 03-04-2005   #1 (permalink)
Favorite Bike: HD XL1200C
Hi all-
My friend is going to install CRG bar end mirrors on his TBS. Does the bike already have bar ends which the mirrors can clamp to, or will he need to purchase the internal bar adapters as well? Thanks.
Dan
[ This message was edited by: 97TB on 2005-03-04 12:45 ]
97TB is offline   Reply With Quote
Old 03-04-2005   #2 (permalink)
Hi all-
Dan
Old 03-04-2005   #3 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
a stack of 7/8 OD stainless washers and a longer version of the screws that hold the bar ends on is what's required. I have the CRG's. I went the above route as it was cheaper. I can't remember if the adapters will actually work - they wont if they have to fit inside the bars as the TBS bars are not hollow on the ends.
Mick...
Old 03-04-2005   #4 (permalink)
Mick...
Old 03-04-2005   #5 (permalink)
Thanks Mick. Would you happen to know the screw size for those bar end bolts?
Dan
Old 03-04-2005   #6 (permalink)
Dan
Old 11-07-2007   #7 (permalink)
Favorite Bike: 2000' T-bird sport
Ksound's Avatar
Other Motorcycle: None
Extra Motorcycle: None
CRG Mirrors
Hello,
I am looking to do the same. I just got my CRG mirrors in the mail.
Is there some sort of tutorial on the web to install these things?
Thanks,
K
Ksound is offline   Reply With Quote
Old 11-08-2007   #8 (permalink)
Favorite Bike: '04 Triumph TBS
cpallen's Avatar
Other Motorcycle: '05 BMW R1200 GS
TBS Bar End mirror mounts
There isn't any space on the end of the bar to clamp the mirror to, nor can you install the internal mount adapter they sell:
because the stock TBS Bars have a (5mm) threaded insert welded in the end. What Mick is suggesting is to fasten a stack of washers to the bar end insert that will create a surface for the mirror to clamp onto outside of the grips instead of trimming or moving the gips and controls inboard to create the clearance.
Courtney
cpallen is offline   Reply With Quote
Old 11-08-2007   #9 (permalink)
it works a charm I used it for a while unil I changed to non OEM bars, I then just moved my switches etc to reveal the right amount of bar.
If you cant get washers quite large enough to bite you can wrap some black electrical tape around the stack too.
Mick...
Old 11-08-2007   #10 (permalink)
Favorite Bike: 1993 Trident
Other Motorcycle: Super III
Extra Motorcycle: BSA heap of Spares
I did this too - when I unscrewed the bar end weights and discovered the lack of hole I fitted an ebay (£5/ $10) Renthal bar off a Suzuki Bandit - the mirrors make up for the loss of the weights....
Ben Rawlinson is offline   Reply With Quote
Bar ends mepeck Club Cafe 6 03-14-2007 07:32 PM
Bar ends? bigeffinpimp Hinckley Classic Triples 9 01-12-2006 09:23 AM
Bar ends on a TBS super3 Hinckley Classic Triples 3 09-19-2005 09:09 AM
Bar Ends VelvetHog Speed Triple Forum 16 08-28-2005 12:42 PM
