TBS Igniter - Triumph Forum: Triumph Rat Motorcycle Forums
 3Likes
  • 2 Post By WSC
  • 1 Post By CharlieS
post #1 of 10 (permalink) Old 04-20-2017, 04:01 AM Thread Starter
Newbie
Main Motorcycle: Honda 954 Fireblade
Rooty111's Avatar
TBS Igniter
Hi all,
Apologies as there are quite a few posts on this subject but I haven't found the exact answer Im looking for.
The igniter on the TBS is toast. I can't find a replacement T1290063 anywhere. I have picked up from other posts that there is the aftermarket option and I'm weighing that up....seems a good way to go.
However can anyone confirm before I do that if a T1290060 or similar will work instead or will the timing be so far off it'll run like a brick?
Thanks
Rooty111 is offline
post #2 of 10 (permalink) Old 04-21-2017, 07:19 AM
Main Motorcycle: Thunderbird sport 2000
Zee9's Avatar
I e heard about the ignitech igniter and people speak highly about it. I think @IrlMike even has a map (setting chart) for it. It's important to check heather you have a 10 pin or 18 pin igniter.
Search for ignitech and maybe you'll find some useful posts
Zee
2000 Triumph Thunderbird Sport
2015 BMW F700GS
Zee9 is offline
post #3 of 10 (permalink) Old 04-21-2017, 07:36 AM
Main Motorcycle: 2004 TBS (modified)
Other Motorcycle: 1998 TBS (stock)
Extra Motorcycle: 2008 Daytona 675
I have the ignitech igniter and it works very well. If your bike is modded, you can raise your rev limiter and adjust some other parameters. Shipping from Czech Republic is relatively quick as well.
Part number looks to be for the 10 pin igniter. If you are interested in staying OEM, I have a spare already boxed (had been sent to Ovni for his diagnostics). Shoot me a PM if interested
simplyj is online now
post #4 of 10 (permalink) Old 04-21-2017, 08:40 PM
Zee9's Avatar
I wish someone had a 10 pin ignitech that I could borrow to see the difference.
Zee
2015 BMW F700GS
Zee9 is offline
post #5 of 10 (permalink) Old 04-24-2017, 07:36 AM
Main Motorcycle: '08 Bonneville T100
Legend JJ's Avatar
I'd highly recommend switching to IgniTech too. Consider upgrading everything else in the ignition system while you're at it, you will definitely notice the difference! Here's the list I was running on the Legend with great results...
Programmable Ignitor Box
PN: SPARKER TCIP4
Bought from: IgniTech (Czech Republic)
http://www.ignitech.cz/en/vyrobky/tcip/tcip.htm
Sales: ignitech@ignitech.cz
Sales Rep: blanka.vasova@ignitech.cz
Once you have the box, install the programming software on your computer from their website. Then you will be able to upload The IrlMike Map file I attached. You can push that map to the box using a USB to Serial Converter. If you don't have one they can be found online fairly easily (Search PN: TU-S9). You'll need to install the Ignitor Box to the TBS, turn the ignition key to On (without starting it) then attach the Serial Converter to your computer for it to accept the map upload. The Ignitor will work just fine right out of the box but I did notice a faster throttle response after I uploaded the map.
Nology ProFire Ignition Coil for Triumph
PN: 152-001-060T
QTY: 3 EA
Nology Hotwires Spark Plug Wires Triumph 3 Cylinder
PN: 012-123-101
QTY: 1 SET
Bought from: New Level Motor Sports
http://store.newlevelmotorsports.com/
Word of advice on the Hotwires: Slowly cut away the excess rubber on the outer part of the rings until you get a good seal with solid contact to the spark plug. See link for pic reference: http://www.triumphrat.net/hinckley-c...-question.html
Lastly since you're upgrading the ignition system I would suggest buying NGK Iridium Spark Plugs (PN: DPR8EIX-9) if you haven't already.
File Type: zip The IrlMike Map.zip (727 Bytes, 10 views)
Legend JJ is online now
post #6 of 10 (permalink) Old 04-24-2017, 10:34 AM
WSC
Main Motorcycle: '04 Thunderbird Sport
WSC's Avatar
Other Motorcycle: '99 Legend TT
Extra Motorcycle: Thunderbolt, T150V
If you instead get the DCPR8EIX-9 plugs (Same exact plug except they have a 16mm hex) you'll find them easier to install if you don't have the factory plug socket..
avu3 and Zee9 like this.
John
Laconia Bike Week 2016 See you next year!
2004 Thunderbird Sport
1999 Legend TT
1975 T150V, 1968 BSA Thunderbolt
WSC is offline
post #7 of 10 (permalink) Old 04-25-2017, 03:00 AM Thread Starter
Newbie
Rooty111's Avatar
Thanks for the help guys.
My mate is actually looking to sell the bike and we've managed to source a working original pretty cheap but if he were keeping it I think the Ignitech sounds ideal. I did get a quote off them and I've read stories on here of them taking a while to reply but they were really quick getting back to me.
Thanks again.
Rooty111 is offline
post #8 of 10 (permalink) Old 04-25-2017, 10:21 AM
Main Motorcycle: 2012 Tiger XC
CharlieS's Avatar
Other Motorcycle: My RED '02 Sprint ST
Extra Motorcycle: 99 Thunderbird Sport
Thanks again.
They were quick to reply to me, and very quick to ship. DHL did a great job, too. From the time I first contacted Ignitech, I had my igniter in a week. Not bad from Czechoslovakia to St. Louis.
---Charlie
CharlieS is online now
post #9 of 10 (permalink) Old 04-25-2017, 10:48 AM
Zee9's Avatar
If you don't end up restoring the bike and it's a 10pin i'll buy it off you Charlie
Zee
2015 BMW F700GS
Zee9 is offline
post #10 of 10 (permalink) Old 04-26-2017, 07:57 AM
CharlieS's Avatar
The bike is definitely going back together. No selling of parts here.
avu3 likes this.
---Charlie
Igniter for TBS or Equivalent ovni Hinckley Classic Triples 3 03-28-2017 03:12 PM
Thruxton R vs TBS CharlieS Hinckley Classic Triples 36 12-13-2016 01:05 AM
Comparing my TBS with other T3s rohart Hinckley Classic Triples 18 06-18-2016 03:49 PM
value of a 2004 TBS front end? simplyj Hinckley Classic Triples 19 11-05-2015 05:38 PM
Ignitech vs stock igniter and FP vs stock needles Vertigo1 Hinckley Classic Triples 5 08-31-2015 01:57 AM
